no dont adjust it up, you'll burn the throw out bearing upits either the pilot bearing is toast or input bearing in the front of tranny
better pull the tranny tomorrow, you have a R150 right
dude, it kinda sounds like your input bearing is spun dry, falling out of any gear is the first sign a rebuild is near
Unfortunatly I'd say from your discription of when it is occuring, Glen would be dead on. Since it only occurs once you let the clutch out it has to be in the trans, usually a throw-out will squeal when you depress the clutch since that's when it spins. The bearings in the trans will stop spinning when you depress the clutch and will start once you start letting the clutch out.
I will refrain from pickin on you and your Toyota always breakin down You should talk to Jeremy about it BD.... He knows quite a bit bout em, he might even take a look if you ask him to. PM me if you don't have his number I'll send it to ya
seems that it is running better than your ford at least
Sounds like something is up with your transmission to me... Here's a scary question: Is there any GEAR OIL in your trans??
I don't know.. don't jump to any conclusions just yet. How does it drive? Any difference in sound while on heavy throttle or just coasting?
It is possible that it could be the throwout bearing. I have seen it before. If it's just barely touching the clutch enough to spin it and it has a bad spot it will sqeal.
the sound is only there when the pedal is all the way out.
My tranny does fall out of 1st and 3rd
Dag nab it!! Its been falling out of gear for 2-3 years now
Now that is a correct symptom of a bad release bearing. But his does not make any sound until the clutch pedal is released.
Started by BLACKDOG « 1 2 » Engine
Started by don25 Engine
Started by wildchild1066 Toyota Pickup/4Runner Tech 1979-95
Started by 83MT Toyota Pickup/4Runner Tech 1979-95
Started by LittleSteve « 1 2 » Project Research and Build-Ups
