Author Topic: GOING WIDER, rear axle swap  (Read 5665 times)
eightyfive
  • Turtle Points: 232
  • Male Posts: 552
  • Member since Dec '05
« on: Apr 16, 2006, 06:48:23 PM »
OK, i have a IFS rear axle to swap in. problem is, i like to get all the tools and stuff needed to do this in one shot.
do i need bleed the brakes?
if i do, then i will lengthen the brake lines.
if i lenghten the rear, i'll be doing the front too.
i ordered spacers on ebay for 45 bucks...
and since i'll be bleeding the front brakes, i'll be upgrading them while im at it.
--what year LC rotors do i need?
i'll be buying a torque wrench sometime during this week.
do i need anything else?
._________________________________________.
||____________||____________||___T0Y0TA__||
||____________||____________||____________||
1985 TOYOTA 4RUNNER
some modifications here and there....
MiniSimp
  • Outdoor Enthusiast
  • Male Posts: 5,120
  • Member since Jan '05
  • SimpsonBrothers.net
Re: GOING WIDER, rear axle swap
« Reply #1 on: Apr 16, 2006, 06:52:47 PM »
1. Yes
2. No, just use the lines that are on the wider axles.
3. Yes, you'll be bleeding the entire system including the LSPV.
4. 1985
5. Good Idea
6. Metric Wrench Set, 12pt socket for the spacers, PB Blaster, Antisieze, Spend the $90 to calibrate your torque wrench.
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #2 on: Apr 16, 2006, 06:54:00 PM »
you dont have to open the front brakes to install spacers.
but yea  i'd install longer  braided lines if you can
MiniSimp
  • Male Posts: 5,120
« Reply #3 on: Apr 16, 2006, 06:55:52 PM »
No, but he might as well blead them since he is bleeding the rear.
eightyfive [OP]
  • Male Posts: 552
« Reply #4 on: Apr 16, 2006, 08:15:26 PM »
calibrate torque wrench?
another question...going vented rotors...does it take long? is it difficult? i remember finding a tech writeup on it but counldn't find it again. i just spent 2 hours looking all over the place.
1985 TOYOTA 4RUNNER
brainlessfool
  • Turtle Points: 2730
  • Male Posts: 4,207
  • Member since Jun '02
    • Buy me a cigar
« Reply #5 on: Apr 16, 2006, 08:23:24 PM »
going "vented" you will need V-6 calipers, other than that you may need to grind on the dust cover a little bit. no big deal.
eightyfive [OP]
  • Male Posts: 552
« Reply #6 on: Apr 16, 2006, 08:26:02 PM »
is removal of the hub hard? do i need any special tools for removing the hub? i once read that the wheel studs are difficult ot take off.
1985 TOYOTA 4RUNNER
MiniSimp
  • Male Posts: 5,120
« Reply #7 on: Apr 16, 2006, 08:30:08 PM »
Yeah, it makes sure your torque wrench is accurate.
There is a place in Chino
Torque Wrench
Address: 13310 Euclid Ave, Chino, CA 91710
Phone: (909) 591-1979
brainlessfool
  • Male Posts: 4,207
    • Buy me a cigar
« Reply #8 on: Apr 16, 2006, 08:34:14 PM »
if you don't have "auto" hubs it's not to bad, just do one side at a time. so if you get lost you can check the other side.
the studs just drive right out, leave the nut on about 5 threads so it will not bugger things up.
eightyfive [OP]
  • Male Posts: 552
« Reply #9 on: Apr 16, 2006, 09:03:52 PM »
what if the torque wrench is new? it doesn't need to be calibrated right?
1985 TOYOTA 4RUNNER
brainlessfool
  • Male Posts: 4,207
    • Buy me a cigar
« Reply #10 on: Apr 16, 2006, 09:08:56 PM »
is it a "torque beam"? or a click click?
MiniSimp
  • Male Posts: 5,120
« Reply #11 on: Apr 16, 2006, 09:31:14 PM »
No, new torque wrenches are +/- 10%, not too big, but big enough when you are torquing something to 250ftlbs, and it only torques 225ftlbs, or even worse, 275ftlbs.
eightyfive [OP]
  • Male Posts: 552
« Reply #12 on: Apr 16, 2006, 09:52:18 PM »
click click...i got a 100 dollar gift card at sears so im going to buy some new tools....torque wrench is one, and a 200+ socket set...i lost all my useful sockets....lost my 14, 19, 1/2 rachet, 10, just need a new set...
1985 TOYOTA 4RUNNER
cheap sunglasses
  • Turtle Points: 59
  • Male Posts: 256
  • Soon to be shorter and slower :)
« Reply #13 on: Apr 17, 2006, 12:43:17 AM »
Bar-style torque wrenches are old school but theyre cheap and reliable.
'82 on 35's, not much else.
wider rear axle
Last post Dec 25, 2004, 06:42:11 AM
by gmrwizard
Last post Oct 17, 2008, 11:41:37 AM
by Toyotony
Last post Sep 30, 2008, 11:52:08 AM
by jimbo74
Last post Mar 28, 2010, 12:00:13 PM
by flyin hawaiian
Last post Mar 31, 2011, 04:49:23 PM
by GregBennett
