Author Topic: X-member-T-Case lift Question!!  (Read 1467 times)
CTENG in KS
  • Turtle Points: -501
  • Male Posts: 4,295
  • Member since Jun '04
  • ^Alfred the Great
    • CTENG's Eco-Rant
« on: Mar 28, 2006, 10:07:15 AM »
Who has raised the transfer case mount on a stock length driveline?  How much did it extend your front driveshaft...mine is a little long, and I wouldn't mind a litle extra clearance under there...
  • Turtle Points: 1174
  • Male Posts: 5,060
  • Crawlin with Marlin
Re: X-member-T-Case lift Question!!
« Reply #1 on: Mar 28, 2006, 12:07:42 PM »
Just get the Marlin Heavy Duty Cross-Member, or similar, and call it even.  You will gain some additional clearance and keep the drivetrain in the factory locations.
 :twocents:
CTENG in KS [OP]
  • Male Posts: 4,295
  • ^Alfred the Great
    • CTENG's Eco-Rant
« Reply #2 on: Mar 28, 2006, 01:29:13 PM »
OK, let me be clearer, My front driveshaft is a wee too long and needs to be shortened.  I was thinking though, what if I put a spacer or something under the t-case and raise it up a bit?  It should extend the front driveshaft a bit and decrease the angle as well...anybody have any knee-jerk reactions as to this being a bad fix?
MiniSimp
  • Outdoor Enthusiast
  • Male Posts: 5,120
  • Member since Jan '05
  • SimpsonBrothers.net
« Reply #3 on: Mar 28, 2006, 01:36:31 PM »
It will increase your angle.
CTENG in KS [OP]
  • Male Posts: 4,295
  • ^Alfred the Great
    • CTENG's Eco-Rant
« Reply #4 on: Mar 28, 2006, 01:50:05 PM »
If you leave the motor mounts alone then the t-case will move in a slight arc as you raise it, although for all intents and purposes it is probably negligible either way...I really wanted to know how much it will affect driveshaft static length.
  • Male Posts: 5,060
« Reply #5 on: Mar 28, 2006, 03:25:12 PM »
I would think it would change it about zero.  It certainly won't change it enough to matter when compared to the travel in the splines.
MiniSimp
  • Male Posts: 5,120
« Reply #6 on: Mar 28, 2006, 03:53:33 PM »
Measure from TC flange to front flange.
Figure out how high you want to raise the TC.
Measure from Imaginary TC flange to front flange = new length.
whiteman
  • Turtle Points: 669
  • Male Posts: 1,276
    • Buy me a cigar
« Reply #7 on: Mar 28, 2006, 04:18:57 PM »
It is not going to help your angle in any way.
In theory yes it will move in an arc type motion, but you cant raise it high enough to make a noticable difference.  You will kill your motor mounts, and if it is tillted to far forward your valves in the back of the motor may be starved of oil.
I just dont see it doing any good unless you are looking for ground clearance, and still i only tilted mine 1" :dunno:
CTENG in KS [OP]
  • Male Posts: 4,295
  • ^Alfred the Great
    • CTENG's Eco-Rant
« Reply #8 on: Mar 29, 2006, 06:57:45 AM »
WERD, good info, thanks people of the sun!
Last post May 29, 2002, 03:06:27 AM
by BigMike
Last post May 26, 2005, 08:35:57 PM
by oddball
Last post Sep 07, 2005, 05:16:13 PM
by Toyminator
Last post Jan 07, 2006, 11:23:46 AM
by RustRunner
Last post Aug 29, 2011, 06:10:30 AM
by dmczeke
