3rd member question
Started by trailhunter, September 03, 2005, 06:53:38 PM
trailhunter
ive noticed that my 3rd member has a paint code on the big nut behind where the drive shaft bolts up to.
Does this paint code tell me what gear ratio is in it? And if it is, what does pink mean?
Thanks
mudmaster
I believe it does and sorry I don't know the codes
Time to go wheelin!
KWP
It does tell you the gear ratio. I believe pink is 4.10
88 Toyota truck ( Under Construction ) Dana 60's front and rear 5.38's, welded diffs, 3inch Downey rears up front,one link rear with aerostar coils rolling on 39.5x16.50/17 Pittbull Rockers and 17x9 Pro Comp extreme alloys.http://board.marlincrawler.com/index.php?topic=40816.0
trailhunter
what do the other colors mean?
Are your gears stock?  If so look for the axle code either on the tag in the engine bay or in the door jamp.  It's usually on the last or one of the last lines and will start with a g, like g382.  Either post up the code here and I'll tell you what it is or go to toysport.com and check their chart.  If your truck is the one in the avatar and is 4cyl with manual tranny it's most likely 4.10.
trailhunter
Quote from: kneedownnate on September 03, 2005, 11:05:19 PM
thanks dude
Toyminator
Quote from: trailhunter on September 03, 2005, 06:53:38 PM
Thanks
Yes.
Pink =4.10
Blue =4.30
Yelllow =4.56
White =4.88
