Painted my MC sliders and slapped some skateboard deck tape on top to help with the traction. Did an oil change and changed my dif fluid n such. I also replaced my spark plugs but ran into more issues, i think my fuel filter it toast because when i tried to start the truck it just died 2 seconds after starting or if i try and give it gas. Cant do anything else to it tonight because everythings closed around town. hopefuly replacing the fuel filter will do the trick.
did u run out of gas or soemthing? i would check the pre-filter in the tank itself then the fuel filter
I took the weekend to install my front diff with fresh 4.88 gears and took the time to rebuild the front steering kuckles and seals. And I don't EVER want to take apart that crap again. The smell of gear oil will make me vomit next time I smell it. Its terrible.
Hahaha get used to it you are going to find yourself in there again
My plan was to order the knuckle rebuild set, wheelbearings and HD oil seal from Marlin.But the ISK to $ currency exchange is not very good for me now. So I´m gonna have to find a place that sells this locally and piece the set together myself.So I just changed the motor oil and filled up my front diff.
Just so you know, All Pro Offroad has a sale on the knuckle rebuild kits right now for $66.75. That is what I used to rebuild my steering knuckles.http://allprooffroad.com/pickupdrivetrain/72
Finally got my first gen running again after nearly 2 years! Still need to do some fine tuning and finish up the exhaust, but at least I can go out, turn the key and it'll fire off!
i love your sig your down to a half of a maverick
Started by toyotaboy Trail Reports, Events, and Gatherings
Started by hawaii500_1999 Trail Reports, Events, and Gatherings
Started by freds40 Trail Reports, Events, and Gatherings
Started by toywthbdydmge Trail Reports, Events, and Gatherings
Started by Tomota Trail Reports, Events, and Gatherings
