(sorry denver83toy, dont mean to jack your thread) so if i use the IFS hub, rotors and slap it on there will i still get 3 inches wider up front and be able to use the V6 calipers as well with no spacer?
ok i need confirmation on this. i know someone who just did a SAS swap on a 86? runner. and he isnt going to use the ifs components. and i could get it for free. so i could use the calipers and rotors off the front and put them on my solid axle? sorry if i missed the obvious point here.
ebay alert I got my rotors for 49.95 a pair + s/h the dude sells them online for 80.00 @ www.jtoutfitters.comand lists them on ebay with a starting bid of 49.95 I got 2 pair and nobody ever bid against meI'm going with the rear disk as well got hooked up here with some brackets that use yota solid axle calipers but I figure if they will bolt up then the v6 ifs calipers should as wellthe only thing that kind of sucks is the rotor goes on the back side of the axle flangebut thats better than chevy chit not to mention I will have a total of 16 pistons on 4 rotors I should be able to make change for that dimethe kit also included an adapter plate for the master cyl. to use an 1 1/4 " bore dare I say chevy master, I plan on posting pic's when it's done
Yes , very easy all bolt on. you will spend about a day of light, well I did because I like things rebuilt and clean, it's a long process to remove all and put back together.Yes it's worth it, espeacially if you have added weight to your rig like bigger tiresno you do not need to run the 1" master I have a 82 4x4 with 35's / 36's, winch , dual cases and a V6 engine, big bumpers yata yata, the V6 upgrade was Awesome ! I never did the 1" master and had stock rear brakesgood luckany other questions search on pirate4x4 boardgood luck
No, the IFS calipers bolt up with Fj vented rotors for the brake upgrade. To widen the front use theIFS hub,caliper and spacer, its the same as using a spacer on the outside of the hub but some people dont believe in using spacers (afraid they come loose) and doing it this way the spacer is bolted in behind the hub.
Will the Larger Master Cylinder also 'mount right up - bolt right in' place of the stock one in an '85? Even though the stock one is fine... is it no biggie to upgrade - replace the Master Cylinder while we're at it, too?
Started by jr9162 Toyota Pickup/4Runner Tech 1979-95
Started by 79toy20r Toyota Pickup/4Runner Tech 1979-95
Started by blackdiamond Project Research and Build-Ups
Started by 95toyrunner Toyota Pickup/4Runner Tech 1979-95
Started by 85_longbed New Member Check-In!
