I did a search but did Not come up with a part number for the correct dip stick.I have the stock Tacoma one and it is to long.I seemed to have the rest of the parts right except that one (at least that is the way it's looking).
Looks like a homemade shroud to me. I would not expect those butt splices on the fan wiring to be very reliable. You may want to put a 22r/e fan and shroud on there or check some other builds in regards to how they did their electric fans. Otherwise nice truck. Also in regards to the air filter box, it is easiest to use the 3.4 box as its shallow enough to fit where the original battery sat.
You can manually operate the IAC valve with a 12v source.Google "IAC test tacoma". I'd close it, leave it disconnected, and see if that solves the high idle. If not - suspect vac leak.If so, reconnect it and see what happens.
Started by cruzila « 1 2 ... 32 33 » Rig Gallery
Started by yotaboy79 « 1 2 ... 32 33 » Chit Chat Camp
Started by BLACKDOG « 1 2 ... 11 12 » Chit Chat Camp
Started by Willy Mammoth « 1 2 3 4 5 » Chit Chat Camp
Started by Rocksurfer Chit Chat Camp
