I have an MSQ (which is the full tune that will contain the timing map) from MS 3.0 guys. You could open it in tunerstudio and likely extract the timing map. When you get that close - email me... This will be my 4th MS project.
I thought your username was familiar, and it just hit me. Did we swap PMs and then emails over at 4Runners.com?
Hey fellas I'm currently running 4.88s in my 85 with 3rz swap on 33s. I'm considering bumping up to some 35s and I'm wondering if I should look into going to 5.29 as well or if the 3rz is powerful enough that I'll be alright?
I thought my 3rz ran awesome with no cat. No 02s.. and just the exhaust lead pipe.. after installing cat and the rest of piping I noticed a significant decrease in power
I'd stay away from running without 02s. No way to get closed-loop operation.. Likely impacts fuel economy under cruise (part throttle) conditions.Modern high-flow cats shouldn't create much backpressure.
Couldn't resist not driving it after it would fire up clutch would slip. Nice power. Not meant to run without O2s and a cat.
What kind of psi are you aiming for? What size turbo and spool are you trying to get?
I'm still troubleshooting the 3rz I got from H8pvmnt... Fixed a couple little vacume leaks and working on a huge Exhuast manifold leak tonight. Wondering if most of the 2rz sensors are the same? I have a buddy with a 2rz and I was gonna try a couple sensors off his.
Started by cruzila « 1 2 ... 32 33 » Rig Gallery
Started by yotaboy79 « 1 2 ... 32 33 » Chit Chat Camp
Started by BLACKDOG « 1 2 ... 11 12 » Chit Chat Camp
Started by Willy Mammoth « 1 2 3 4 5 » Chit Chat Camp
Started by Rocksurfer Chit Chat Camp
