Author Topic: SAS wheel stud problem  (Read 2381 times)
papasmurf
  • Turtle Points: -8
  • Member since Nov '05
  • Crawling with Marlin in Ohio
« on: Nov 30, 2005, 10:05:21 PM »
Can anyone tell me the length of a stock wheel stud from a 84-85 front Toy axle?  I'm not getting enough threads on my stock studs thru my 1.5" spacers.  Anyone know the length so I don't have to tear it down to look around?  Anyone know where to find longer studs?   :hammerhead:  all day long!
You can't get there from here!
TEXCRAWLER
  • Turtle Points: -586
  • Male Posts: 566
  • Member since Aug '05
  • ROCK GOD!!!
Re: SAS wheel stud problem
« Reply #1 on: Dec 01, 2005, 01:31:54 AM »
the studs should be about 1 1/2 inches or 2 stock. If you need longer studs try ACE hardware.
87' Samurai, Dimond-F, Tacoma-R, 5.29 F-detroit R-spool,6 Stud knukles, 4-link coils F&R, Duel Marlin chromoly 4.7 Toyota T-Case, 39.5 TSL's, 8000 lb winch, 6 piont cage, Full Hydro, Sidekick 1.6 16V, Thourly header, LongField 30 splines, 115" WB, crawlin @ 459:1
I could care less for turtle points.
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
« Reply #2 on: Dec 01, 2005, 01:52:31 AM »
not sure if i would go to ace hardware to get wheel studs... and wheel studs arent jsut regular bolts either.....
Cheesemaker
  • Turtle Points: 1363
  • Male Posts: 4,525
  • Member since Sep '04
« Reply #3 on: Dec 01, 2005, 02:15:59 AM »
Try a parts house or your local tire/brake store.  At Les Schwab Tires we used to have a large wheel stud collection, and sometimes aftermarket wheels were too thick to get enough exposed threads for the lugnuts!  Just cross reference the knurl diameter and thickness at the base of the stud, with one that has a longer thread count!  It might be time consuming, but well worth it in the long run!
papasmurf [OP]
  • Turtle Points: -8
« Reply #4 on: Dec 01, 2005, 06:43:31 AM »
Hey, Thanks ya'll  I have a lot of work to do yet on the front (brakes, driveshaft, bump stops, shock mounts) before I'm going to tear the spindle apart to pull a stud.  I was hoping there was a standard stock length someone could tell me so I could source the studs while out running around.  I guess I really shouldn't get ahead of myself!  Thanks again!
Prismo
  • Turtle Points: 8403
  • Member since Oct '03
  • Living in the green house
« Reply #5 on: Dec 01, 2005, 06:51:55 AM »
Come on by, I have some extras in the garage. Free of course.
ol yeller
  • Turtle Points: 76
  • Male Posts: 66
  • Member since Jan '04
  • whoops
« Reply #6 on: Dec 01, 2005, 07:39:06 AM »
Whats up brother, didnt know you were getting on the board.  Good luck, you know I dont have the answer
One Day...DUAL TRANSFER!!!      Go hard or go home.
Riddett
  • Male Posts: 35
  • Member since Aug '04
  • Not Many Rocks, but we got mud in Virginia
« Reply #7 on: Dec 01, 2005, 10:12:02 AM »
You can try using the rear studs if you have an old axle laying aroound. If I remember the rears are a tad longer than
the front's.
flipskid
« Reply #8 on: Dec 03, 2005, 10:54:45 PM »
check the pbb, they make 2 different lug nuts for the spacers, one has a longer thinner neck on it the grabs more threads.  Chris gieger can get them so can marlin.
Last post Nov 02, 2008, 06:27:25 PM
by muddytaco
Last post Sep 25, 2008, 11:15:18 AM
by booger1
Last post Dec 21, 2008, 10:55:36 PM
by jrock
Last post Jun 25, 2012, 07:44:06 PM
by ikaria
Last post Apr 15, 2013, 07:54:42 PM
by lone walker
