rear wheel stud stuck
Started by booger1, September 22, 2008, 11:07:50 PM
booger1
on my 93 one of the wheel studs got rounded off :smack: . I tried to weld lug nut on damaged one and no luck, it just kept breaking off and i don't have a torch.  in middle of buildup with 7mge swap and someone just offered to swap wheels so not driveable yet.  I was wondering, is it possible to unbolt axle shaft and get in there with a angle grinder from back of stud or will i just mess it up?
93 pickup,  sas'd, 36in tsl's, tundra front clip, taco bed, kenwood, apexi intake,  7mgte.
booger1
Rockcrawlintoy
weld again and turn the heat up
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
just throw a 12 point socket on it, hammer it on, and spin it off....
this is actually how tire shops remove wheel lock kits when people lose their keys
booger1
got it off. ended up unbolting axleshaft and found someone with propane torch  :flamer: . now I got 15x10's instead of 15x8's  :beerchug:
Quote from: jimbo74 on September 23, 2008, 12:01:11 AM
Must be a crappy tire shop, they make special sockets to remove wheel locks. Wheel locks will only keep the novice from getting them off.
Quote from: Rocksurfer on September 24, 2008, 07:29:41 PM
we had the lock off sets too, but sockets are much cheaper, i've used this method several times.. used it on a set i had @ home too.... and im saying most people dont have the lock off tools.... a 12 pt works jsut as good.....
i've worked for america's tire company, and wheel works; several other tire companies employ the same method as well
Won't find me banging my sockets on a bad lug, kinda screws them up and they ain't cheap and if they are cheap that's probably why you are having to do it in the 1st place. I just went through this same issue with 2 lugs on my Durango, and even my lock sockets wouldn't work. Ended up having to drill and torch them off.
...and no I never even considered banging on a socket, wouldn't have worked anyways.
Quote from: Rocksurfer on September 24, 2008, 07:41:20 PM
if you havent tried it, how do you know it doesn't work?
i am not saying this method always works, but i have personally done this on many thpes of sheel locks, also have used an air chisel on some types as well
Oh I bet it works but like I said I'm not going to destroy my sockets. Plus in my case I didn't round off my lugs until much later in trying to remove them. I've never seen any good come from smacking a socket.
Quote from: Rocksurfer on September 24, 2008, 07:52:17 PM
sockets are a dime a dozen...... i have sooo many sockets, in the same sizes its not even funny... usually ,i was able to find a socket befroe i am able to find the real tool.....
i've done it several times with quite a good deal of success, and not everyone has the wheel lock removal sockets..... 12 point sockets are pretty useless anyways ;)
My Snap-On tools will not be hammered unless they are supposed to be hammered.  :shake:
Tallchevy
Quote from: rockcrawlintoy on September 22, 2008, 11:45:35 PM
X2
I know you got it off already but I just did this a few weeks ago to get the lock lugs off my parts truck. I got a nut that was large enough so that the lug nut would almost fit & filled the center. my came off with no problems.
Quote from: Rocksurfer on September 24, 2008, 08:11:28 PM
X2
87 4Runner redo
booger1
actually,  I already tried the socket thing before  :flamer: i forgot to mention that I already took a chisel to it, trying to make it spin and the lug nuts were cheap and weren't even long enough. last owner did it :maddest:
