Author Topic: 1992 Trail Rig Project  (Read 30633 times)
Oregon Crawler
  • Turtle Points: 26
  • Male Posts: 197
  • Member since Nov '05
  • GET IT!!!
Re: 1992 Trail Rig Project (update 11/8/06)
« Reply #60 on: Nov 16, 2006, 08:10:41 AM »
        No, I havn't used a 4 link calculator. So If I move my lower links up at the axle end it'll help? I Got this idea of mounting on a comp rock rig I saw on TV it acts like a rock slider. with rear flex steer as bad as it is right now, it's no good. As long as It's have a little, no big deal thanks for all the info
1992 yota truggy, 37" boggers, 7m-w56-duals, 85' front axle w/44 joints, 4 Link-coils in rear, marlin springs front, and ur mom in the passenger seat!!!
4RnrRick
  • Turtle Points: 60
  • Member since Jan '04
« Reply #61 on: Nov 16, 2006, 09:35:38 AM »
You need to converge your lower links to reduce rear steer.
BTW - where in Oregon are you? I'm just south of Eugene.
CTENG in KS
  • Turtle Points: -501
  • Male Posts: 4,295
  • Member since Jun '04
  • ^Alfred the Great
    • CTENG's Eco-Rant
« Reply #62 on: Nov 16, 2006, 09:44:55 AM »
it will help reduce longitudinal displacment of the link end throughout the useable arc of the suspension travel.  As stated before, however, unless you triangulate, you won't be ablt to fully eliminate the flex steer.
Oregon Crawler [OP]
  • Turtle Points: 26
  • Male Posts: 197
  • GET IT!!!
« Reply #63 on: Nov 16, 2006, 11:41:36 AM »
I live in medford and for the links. I think of mounting the lower links on top of the axle extending the lower ones a few inches, anyways I'm hopefully have the tranny and motor in and mounts built and finished.
yotadork83
  • Turtle Points: 18
  • Male Posts: 705
  • Member since Mar '06
  • ninja turtules rule!!
« Reply #64 on: Nov 16, 2006, 01:01:59 PM »
if you get 5mge motor mounts you can bolt the 7mge in the same place as the 22r.
yotas 4 life homie!
4RnrRick
  • Turtle Points: 60
« Reply #65 on: Nov 16, 2006, 01:47:10 PM »
5mge motor mounts (the steel part that bolts to the block)
then you can use the 22R/RE/RTE, 2RZ or 3RZ Rubbers
And that will bolt right to the 4 cylinder frames.
Heres what they look like.
« Last Edit: Nov 16, 2006, 01:58:26 PM by 4RnrRick »
4RnrRick
  • Turtle Points: 60
« Reply #66 on: Nov 16, 2006, 01:50:42 PM »
BTW if you need a reference thread on a 7MGE install, look here:
http://board.marlincrawler.com/index.php?topic=11982.0
I would recomend installing ARP studs and a Metal Layered Head Gasket before you install the motor!
Good luck when you get to this part... :thumbs:
« Last Edit: Nov 16, 2006, 01:59:49 PM by 4RnrRick »
ddog87
« Reply #67 on: Nov 16, 2006, 03:05:36 PM »
MAN YOU SUCK :yikes: This is almost identical to the build I have been talking about doing. I am planning on using an extra cab though. Have you thought about what you are going to do about brakes with the 7m motor in there.
Oregon Crawler [OP]
  • Turtle Points: 26
  • Male Posts: 197
  • GET IT!!!
« Reply #68 on: Nov 16, 2006, 03:44:38 PM »
   Well I have custom motor mounts anyways I'm just going to cut them and move them, My cab is moved back on the frame, same with the motor mounts. and
        4nrRick I'Ve read most of your thread and all the supracharged.com threads to. Good job on your build that toy is sick.
Oregon Crawler [OP]
  • Turtle Points: 26
  • Male Posts: 197
  • GET IT!!!
« Reply #69 on: Nov 16, 2006, 03:47:46 PM »
brakes, exactly what part are you thinkin is goin to be a problem
Hottrod81
  • Turtle Points: -2
  • Male Posts: 1,392
  • Full Trucker Effect
« Reply #70 on: Nov 16, 2006, 04:14:59 PM »
Have you thought about lengthening your wheelbase a bit by moving the rear axle back?
Oregon Crawler [OP]
  • Turtle Points: 26
  • Male Posts: 197
  • GET IT!!!
« Reply #71 on: Nov 16, 2006, 06:18:17 PM »
   No, for the trails I do, the wheel base is perfect. I do alot tight trails with alot of high center humps and tank traps, and what not. plus it's long enough to do steep hill climbs with out flipping. Plus moving the cab and motor back this thing is going to rock, plus the power of the 3.0 ahaha it's goin to be awesome. When I go to the coast to do some trails I take and post some videos, and pics. There some narly trails and alot steep hill climbs.
ddog87
« Reply #72 on: Nov 17, 2006, 08:13:47 AM »
The 7m motor just about hits the brake booster when the cab is not narrow.
rickibrat2
« Reply #73 on: Nov 20, 2006, 05:36:25 AM »
have 2 5 foot peaces of dom tubing with 3/4 inserts and hemi ends if you need them to help correect just north of you in dallas
also if you have wire diagram call have made many harness for fuel injectio on pinto rails
rick
503 623 3354
Oregon Crawler [OP]
  • Turtle Points: 26
  • Male Posts: 197
  • GET IT!!!
« Reply #74 on: Nov 20, 2006, 04:40:46 PM »
Ohh I moving the boster over, the steering clears though, hopefully will have the motor in there by end of this week.
Oregon Crawler [OP]
  • Turtle Points: 26
  • Male Posts: 197
  • GET IT!!!
Re: 1992 Trail Rig Project Ended
« Reply #75 on: Nov 23, 2006, 04:34:28 PM »
    Well toyota pickup project has to come to an end. I'm scrappin the frame and cab keeping everything else to swap in a sammy down the road Ohh well,I won't have time to work on it anymore and can't invest any more benji's in it, I will post a build up when the time comes to build a sick zuki.
6.72:1
  • Turtle Points: 73
  • Male Posts: 1,856
  • Member since Mar '05
  • Stuck with 2.5ton Rocks....
« Reply #76 on: Nov 23, 2006, 05:53:24 PM »
Don't let the MGE wiring get you down!
mrkupfer@gmail.com
Cell: (205) 919-3290
www.Kupferphotography.com
yotaboy79
  • stuck in the shop
  • Turtle Points: -19
  • Male Posts: 2,838
  • Member since Aug '03
« Reply #77 on: Nov 23, 2006, 06:15:17 PM »
thats to bad i was looking forward to seeing how this thing turned out how much where you looking to get out of the cab and frame? ive been thinking about building a second truck
Oregon Crawler [OP]
  • Turtle Points: 26
  • Male Posts: 197
  • GET IT!!!
« Reply #78 on: Nov 24, 2006, 05:15:29 PM »
I'll let it go for 100$ including the rear axle housing and the links. No heims tho. but let me know .
yotaboy79
  • stuck in the shop
  • Male Posts: 2,838
« Reply #79 on: Nov 24, 2006, 06:55:35 PM »
where in oregon are you located again?
Gittinit
  • throttle jockey!
  • Turtle Points: 28
  • Male Posts: 2,293
  • Member since Sep '06
« Reply #80 on: Nov 24, 2006, 07:53:10 PM »
Thats dissapointing to hear.  :down:
my favorite places:
http://www.flatnasty.net/
http://www.orvpark.com/
yotaboy79
  • stuck in the shop
  • Male Posts: 2,838
« Reply #81 on: Nov 24, 2006, 10:00:36 PM »
oh and do you still have the factory wiring harness? would you throw that in?
Oregon Crawler [OP]
  • Turtle Points: 26
  • Male Posts: 197
  • GET IT!!!
« Reply #82 on: Nov 25, 2006, 06:15:47 PM »
No I can't throw that in, keepin it for the toy-sammy .
yotaboy79
  • stuck in the shop
  • Male Posts: 2,838
« Reply #83 on: Nov 25, 2006, 09:12:14 PM »
you never answered my other question, where in oregon are you located at?
Oregon Crawler [OP]
  • Turtle Points: 26
  • Male Posts: 197
  • GET IT!!!
« Reply #84 on: Nov 25, 2006, 10:08:27 PM »
« Last Edit: Jan 09, 2007, 08:29:44 AM by Oregon Crawler »
Oregon Crawler [OP]
  • Turtle Points: 26
  • Male Posts: 197
  • GET IT!!!
« Reply #85 on: Dec 03, 2006, 12:33:00 AM »
  Oh ya, not getting rid of it, afterall. I worked some stuff out and I was able to keep it, the build won't be done by end of dec. as I was hoping. I wanting it done by march now but maybe a little sooner, tomorrow I am building the rear shock mounts, getting the motor mounts welded in,I've been fideling with the flex steer in back, It has it still, But I went looking around at other trucks and jeeps, that had the four link the same way, and most rigs have it worst. So for Right now I'm just leaving it.It flex's really well. so post pics tomorrow
Gittinit
  • throttle jockey!
  • Turtle Points: 28
  • Male Posts: 2,293
Re: 1992 Trail Rig Project (Back On!!!!!)
« Reply #86 on: Dec 03, 2006, 12:49:13 AM »
 :booya: I'm glad to hear that you didn't have to give it up. Looking forward to some progress.
my favorite places:
6.72:1
  • Turtle Points: 73
  • Male Posts: 1,856
« Reply #87 on: Dec 03, 2006, 03:23:49 AM »
Yes, another one saved! Let's see those photographs!
mrkupfer@gmail.com
Oregon Crawler [OP]
  • Turtle Points: 26
  • Male Posts: 197
  • GET IT!!!
« Reply #88 on: Dec 03, 2006, 08:40:14 PM »
   Well didn't get as much as I wanted done today but I got the back shock hoop bent and welded on and got the one shock tacked into place.
CTENG in KS
  • Male Posts: 4,295
  • ^Alfred the Great
    • CTENG's Eco-Rant
« Reply #89 on: Dec 03, 2006, 08:49:20 PM »
Any way you can get those shock outboard a bit more?  Might just be the pics, but they look like they are really in far towards the middle.
Last post Nov 06, 2002, 06:41:34 AM
by Brandon
Last post Aug 27, 2002, 07:59:12 AM
by TOYFREAK
Last post Apr 27, 2005, 01:03:27 PM
by toyhunter
Last post Aug 11, 2015, 09:00:26 AM
by LiLredYOTA
Last post Mar 06, 2017, 08:15:00 PM
by Cheesemaker
