Author Topic: im kinda pissed  (Read 4027 times)
crawlerdan
  • Turtle Points: 1319
  • Male Posts: 4,770
im kinda pissed
« on: Nov 29, 2005, 11:46:52 AM »
so my 22re equiped runner runs like garbage intermitantly.
it acted like it was running out of gas/stalling/bogging down
i replaced the fuel filter-plugs-wires-cap and rotor-massair flow meter-tps sensor-and finnally the computer
when i replaced the computer it ran great but a little sluggish, so i put another new one out of a celica in it-and it ran like a raped ape
for about 250 miles and now its doing the bogging down at 2900 or 3000rpm again, completely pissed of and tired of spending money on this thing
MARLIN-MIKE--HELP!!!!!! :beerchug:
brainlessfool
  • Turtle Points: 2730
  • Male Posts: 4,207
  • Member since Jun '02
    • Buy me a cigar
Re: im kinda pissed
« Reply #1 on: Nov 29, 2005, 12:29:04 PM »
you sure that the exhaust systom is open? no back presser?
and the fuel pump is it good? presser AND volume?
MiniSimp
  • Outdoor Enthusiast
  • Male Posts: 5,120
  • Member since Jan '05
  • SimpsonBrothers.net
Re: im kinda pissed
« Reply #2 on: Nov 29, 2005, 12:30:41 PM »
When was the last time you cleaned out your intake manifold?
crawlerdan [OP]
  • Male Posts: 4,770
Re: im kinda pissed
« Reply #3 on: Nov 29, 2005, 12:36:27 PM »
well ill find out about the exhaust soon, im putting ne header and muffler on, so ill check, but i doubt thats the prob, but you never know
crawlerdan [OP]
  • Male Posts: 4,770
Re: im kinda pissed
« Reply #4 on: Nov 29, 2005, 12:36:50 PM »
about 4 months ago
brainlessfool
  • Male Posts: 4,207
    • Buy me a cigar
Re: im kinda pissed
« Reply #5 on: Nov 29, 2005, 01:08:31 PM »
ya got anyway to check fuel psi? not sure on an efi rig what the best way is to check volume? butt it can't be to hard. maybe pull a line and do a timed fill into a can?
Riddett
  • Male Posts: 35
  • Member since Aug '04
  • Not Many Rocks, but we got mud in Virginia
Re: im kinda pissed
« Reply #6 on: Nov 29, 2005, 01:31:26 PM »
Sounds like someting electrical is burning up the computers you keep replacing. I don't agree with a fuel
problem since it runs fine when you put a new computer in. Dist and Computer control the fuel pump on
the 22RE, so maybe a dist problem.
  • Turtle Points: 2158
  • Male Posts: 18,292
  • Member since Apr '02
  • 511:1 Club
Re: im kinda pissed
« Reply #7 on: Nov 29, 2005, 02:12:02 PM »
The distrubitor does not control the fuel pump? The fuel pump is controlled via an Ignition ON condition, and a signal from the air box which grounds the OCR, which completes the voltage to the Fuel Pump. It can also be controlled from the Diag. box, if this system is 1987 or later.
I have to agree with BLF. I would look into the fuel pump for sure. After we finished Marlin's 3RZ conversion, we were using an EFI fuel tank that we had out back. We just figured that the pump was good. But his truck would run great sometimes, and then poor other times. Come to find out, the fuel pump was wasted, and was not reliable at keeping a constant pressure all the time...
However, you are only getting this problem during a certain RPM range, and that would lead me to think it is not a fuel deliverly problem, or at least not a lack of fuel pressure, I should say.
How about your Ignitor? Does it have a good ground? Has it ever gotten wet?
Also, how are your Engine and Chassis grounds?
During the 2900-3000 rpm bogging, is it related to throttle position as well as RPM, or only RPM? What if you were in 5th gear at 2900 rpm, like at 40 mph, and you show plenty of throttle. How does that compare to say 2nd gear at like 10 mph at 2900 rpm with partial throttle?
brainlessfool
  • Male Posts: 4,207
    • Buy me a cigar
Re: im kinda pissed
« Reply #8 on: Nov 29, 2005, 04:06:43 PM »
WHAT? :thud:  this just anit right, and your going to kill my image I've worked so hard for!  :laugh:
crawlerdan [OP]
  • Male Posts: 4,770
Re: im kinda pissed
« Reply #9 on: Nov 29, 2005, 04:36:56 PM »
It seems as though its a throtle position related problem also, it does it in  all gears at that rpm range- but the tps was replaced with a new-not new used- one less than 500 miles ago.ill check out the grounds-as i have moved the ignitor and coil to make room for shock hoops, any other ideas would be apreciated-thanks mike
Oregon Crawler
  • Turtle Points: 26
  • Male Posts: 197
  • Member since Nov '05
  • GET IT!!!
Re: im kinda pissed
« Reply #10 on: Nov 29, 2005, 09:35:44 PM »
    Hey I have a 22re to and a 6  months back same thing happen to me.If i stop at a stop sign it would die. Randomly died driving  and would be sluggish and pudder.  Anyways it was the Fuel Regulater.
1992 yota truggy, 37" boggers, 7m-w56-duals, 85' front axle w/44 joints, 4 Link-coils in rear, marlin springs front, and ur mom in the passenger seat!!!
brainlessfool
  • Male Posts: 4,207
    • Buy me a cigar
Re: im kinda pissed
« Reply #11 on: Nov 30, 2005, 07:58:57 AM »
how does it run after it goes past 29-3K?
if it won't go that far, check fuel pump out.
crawlerdan [OP]
  • Male Posts: 4,770
Re: im kinda pissed
« Reply #12 on: Nov 30, 2005, 08:07:18 AM »
if i keep it reveing, or keep it "under load" it runs fine
and where is the regulator?
Oregon Crawler
  • Turtle Points: 26
  • Male Posts: 197
  • GET IT!!!
Re: im kinda pissed
« Reply #13 on: Nov 30, 2005, 09:58:15 PM »
   It is attached to the fuel rail. On backside  of the intake
Mac5005
  • Turtle Points: -17
  • Male Posts: 307
  • Black Listed
    • NC4x4
Re: im kinda pissed
« Reply #14 on: Nov 30, 2005, 10:23:46 PM »
does that motor have an egr valve?, and if it does, unplug the vacuum line to it, and check this......what happens (if this is the problem) one or more ov the actual egr ports in the intake gets clogged, then sending all that exhaust gas into the remaining unclogged egr ports in the manifold......this causing a lean condition, and making the motor bogg down, at any rpm just depending on the finnike-ness of your motor.....and this problem is completely seperate from the ignition and or fuel system....anyways it takes like 2 secs to unplug the line and cap it off.....its worth a shot just to try it and rule it out
YJ - 4.7L-Ax15-D300(4:1)-D60/14B, lockright/spool 5.38's, 108" WB, 42" SX-2's
Mac5005
  • Male Posts: 307
  • Black Listed
    • NC4x4
Re: im kinda pissed
« Reply #15 on: Nov 30, 2005, 10:27:26 PM »
Another thing....pull your plugs out and look at them just after driving it, and the problem orrurs......especially look at the electrode and the anode, and also the insulator and post up what it looks like.....color, amber, yellow, dk brown, light orange, red orange, ashy grey, black and sutty, white and ashy, black and greasy.....etc, just by pulling the plugs out and comparing each other b/t the 4, and looking at the plug in general, can tell you alot about whats going on in the combustion chamber....also is the problem in any way associated with being hot cold, warm, ran for a long period, after idling for a long period....what is your timing set at?
Last post Dec 07, 2006, 10:24:17 PM
by 86bobbedtoy
Last post Aug 01, 2008, 08:37:28 PM
by Cheesemaker
Last post Oct 18, 2008, 10:33:14 PM
by germ
Last post Nov 17, 2011, 06:40:47 PM
by Gamera
Last post Dec 31, 2012, 06:24:23 PM
by 22rMudToy
