Author Topic: try to get my buildup thread goin  (Read 3570 times)
jedimasteryoda
  • Turtle Points: 134
  • Male Posts: 119
  • Member since May '05
  • not offroading yet all my rigs r down
« on: Nov 03, 2005, 08:06:17 PM »
this is my fj60 landcruiser  i bought it for $300 runnign kinda crappy fuel lines were plugged or sumthing. but anyways to the buildup.
what ive done to it.
put 31" mud kings on it had 29" thornbirds i thoght  were kik a$s in mud but i wanted bigger tires.
fabbed a snorkel out of  a shop vachose and slapped k and n air filteron the end of it.
bought the cheap bed liner rubber crap from walmart and did the whole tub.
 chopped the front fenders and the top off behind the rear doors
extended battery cables so i have it in the back so i have more tire room and i took the whole inner fender wells out
have a 2wd toyota rear leafs inthe front cus my other ones snapped and the onyl one si could find that would fit for the time being.
took the headlights and turnsignals off cus im redoing that whoel part when i get my bumper on.
also bought 3 sets of lights from walmart cheapys so if i break em i can replace them easily.
thats all i can remeber rigth now.
what i plan on doing.
get my 39x18x15 baja belteds on
suspension above axle lift
between 1-3"  body lift if i dont have enough flex room after the suspension lift.
definatley a winch
i want an exo cage and a roof rack for my spare and all my saftey  crap
 bucket seats with harnesses
 the marlin crawl box
 a set of 5.29s
dual optima batterys
electric fan
a locked rear and limited front locked front if its not street legal after im done with it
oh and 63" chevys in the rear . thats bout it 4 now.   heres the pics
its a truck its built for this kind of stuff.
  under my tires is a honda
jedimasteryoda [OP]
  • Male Posts: 119
Re: try to get my buildup thread goin
« Reply #1 on: Nov 03, 2005, 08:12:32 PM »
dang my other pics r on the laptop ill have to post them tommorow.
whiteman
  • Turtle Points: 669
  • Male Posts: 1,276
  • Member since Jan '05
    • Buy me a cigar
« Reply #2 on: Nov 04, 2005, 04:57:56 PM »
Sweet!  I have yet to dee the build up of a late model Land Crusier.   :hyper:
jedimasteryoda [OP]
  • Male Posts: 119
« Reply #3 on: Nov 09, 2005, 05:11:25 PM »
heres a pic of my bumper came off of an old beefed up chevy ill probly need over loads or the front of my beast for this thing. its heavy as hell id say 300-400 lbs
jedimasteryoda [OP]
  • Male Posts: 119
« Reply #4 on: Nov 09, 2005, 05:18:28 PM »
i have a few questions 2    whats the lightest but still strong kinda metal pipe or tubing to build a exo cage out of and which is better for flex 63" chevies or ford ranger leafs?  thanks for your time and any info.
whiteman
  • Male Posts: 1,276
    • Buy me a cigar
« Reply #5 on: Nov 09, 2005, 05:22:16 PM »
I dont know a lot about tubing so I cant answer that.  As for the springs, the chevy's would give you more compared to ranger springs.
whiteman
  • Male Posts: 1,276
    • Buy me a cigar
« Reply #6 on: Nov 09, 2005, 05:23:46 PM »
Let take a guess at the tubing, DOM 1 3/4 .120 .   Am I close. :-\\
jedimasteryoda [OP]
  • Male Posts: 119
« Reply #7 on: Nov 09, 2005, 05:37:05 PM »
i have no idea on tubing. this is my first build up.  i just want to be able to survive it *when* i roll the truck. and want to have a cage on there b4 i do anything too  extreme.
toyrokcrwlr
  • Turtle Points: 124
  • Male Posts: 128
  • Member since Jun '05
  • My Yota
« Reply #8 on: Nov 09, 2005, 07:34:46 PM »
The best pipe to get would be mild steel, schedule 40, 1 1/4"  ID (means Inside Diameter)
« Last Edit: Nov 09, 2005, 07:39:18 PM by toyrokcrwlr »
jedimasteryoda [OP]
  • Male Posts: 119
« Reply #9 on: Nov 09, 2005, 08:21:15 PM »
cool thanks 4 the info
jedimasteryoda [OP]
  • Male Posts: 119
« Reply #10 on: Nov 09, 2005, 09:59:14 PM »
need some more info would long shackles cuase any problems i was thinking about putting the marlin 6" shackles in the front and rear.
yotaboy79
  • stuck in the shop
  • Turtle Points: -19
  • Male Posts: 2,838
  • Member since Aug '03
« Reply #11 on: Nov 13, 2005, 11:06:06 PM »
for the cage you could use any thing from pipe 1 1/4 sch 40 its 1 5/8 od  and a little over 1 1/4 id you could also use 1 1/2 or 1 3/4 round tube .120 wall personaly i think 1 3/4 looks a little big for an exo if you realy wanna get fancy you can use DOM tubing its seamless and a hell of alot stronger but its also alot more expensive than regular seamed round tube or if you realy need some thing that strong and light wieght you could use chromoly tubing but thats a little over kill for a wheeler with DOM and chromoly the steel will have more spring to it so if you roll it wont just bend and stay put it will bend and spring back to its original shape (to a point) both can be bent using a tube bender the chromoly is a little harder to bend
on my exo i used 1 1/2 .125 wall DOM for the main hoop and the rest is 1 1/2 .120 wall seamed round tube good luck and happy building :beerchug:
To The Floor
  • Turtle Points: 220
  • Male Posts: 393
  • Member since Jul '04
  • THE KRAK
« Reply #12 on: Nov 13, 2005, 11:19:55 PM »
for all out strength and looks i'd say 1 5/8" .134 wall DOM.  i like the 1 5/8" tube cuz it's unique.
  • Turtle Points: 679
  • Member since Feb '03
  • Don't blame me, I didn't vote for this crap.
« Reply #13 on: Nov 13, 2005, 11:51:34 PM »
I wouldnt waste my time on an exo.  They get caught on everything here in the PNW.  A good interior cage and beat the piss out of it.  It'll be fun I promise. :greengrin:
Last post Jun 08, 2005, 06:50:38 PM
by MagPede
Last post Aug 28, 2007, 10:37:30 PM
by 84socal
Last post Nov 08, 2007, 03:32:37 PM
by rebelKrawler83
Last post Mar 19, 2008, 04:18:59 PM
by 79coyotefrg
Last post Sep 29, 2015, 02:26:23 AM
by turbo this..
