Author Topic: cuting with propane  (Read 1075 times)
89 toy
  • Turtle Points: -1198
  • Male Posts: 383
  • Member since Dec '03
cuting with propane
« on: Jun 27, 2005, 10:34:15 PM »
has any body used propane instead of acetalyne in their torch. do you have to use a different tip?i ran out of gas while torching the ifs off and am using it seems to work ok but takes a while to heat up.
trevinotrek
  • Turtle Points: 279
  • Male Posts: 236
  • Member since Sep '04
Re: cuting with propane
« Reply #1 on: Jun 27, 2005, 10:51:11 PM »
you dont have to change anything just be careful it has a tip the looks like an after uner. we use it to cut 1  1/2 - 2  " platejust set it low and work up your setting .
aint skeerd " watch this" ok so maby it was a littlte to bigto get over .Stop laughing and turn me over
Last post Aug 22, 2004, 04:24:38 PM
by WHITE_TRASH
Propane?
Last post Mar 22, 2005, 12:24:21 PM
by burnyota
Last post Apr 07, 2006, 08:10:31 AM
by AzBearFan
Last post Jul 01, 2007, 01:19:53 PM
by DTB
Last post Nov 16, 2007, 10:57:10 PM
by YotaJoe
