Author Topic: Starting problem  (Read 1295 times)
ratzila
  • Turtle Points: 18
  • Member since Dec '04
Starting problem
« on: Jun 01, 2005, 02:59:19 PM »
I have an 85 4 runner with the 22re motor. I can start the engine fine but when it warms up you can cut it off and the thing will not start until the motor cools down. A friend of mine had me run a jumper wire for the fuel pump to leave it on all the the time. Has anyone else had this problem? Thanks, David
b_ripper8
  • Turtle Points: 371
  • Male Posts: 275
  • Member since May '04
  • 3RZ-FE power is that much closer.
Re: Starting problem
« Reply #1 on: Jun 01, 2005, 03:13:07 PM »
Your starter may also be over heating. I've had that problem and it's a simple fix with a heat shield.
Last post Jan 23, 2006, 05:05:00 PM
by Zoomschwortz
Last post Oct 19, 2006, 12:00:25 AM
by Wermz84
Last post Nov 28, 2008, 03:09:14 PM
by Nothingface5384
Last post Aug 31, 2010, 12:41:20 PM
by superyota
Last post Nov 26, 2014, 03:37:56 PM
by 1985CRAWLER
