Starting problem
Started by ratzila, June 01, 2005, 02:59:19 PM
ratzila
I have an 85 4 runner with the 22re motor. I can start the engine fine but when it warms up you can cut it off and the thing will not start until the motor cools down. A friend of mine had me run a jumper wire for the fuel pump to leave it on all the the time. Has anyone else had this problem? Thanks, David
b_ripper8
Your starter may also be over heating. I've had that problem and it's a simple fix with a heat shield.
In Progress: 3RZ-FE Swap Underway.
Currently: 87' 4Runner - SAS - 5.29's - welded rear - Dual 2.28 cases - Optima bluetop - round headlight conversion - FZJ80 grill - rattlecan paint job - trimmed fenders - Ranger hybrid springs front - Tacoma hybrid springs rear - schedule 160 drivelines 8" slip front - Marlin's crossmember - disk brake conversion
