Author Topic: Transmission swap questions: L45 to R151f  (Read 1787 times)
Groundpounder17
  • Male Posts: 99
  • Member since Oct '20
« on: Feb 10, 2021, 01:46:31 PM »
I am going to look at a R151f to swap into my '82 pickup to replace the 4 speed.  Anything in particular I should be looking for?  For this swap, if I am wanting to run dual cases would I want to convert the R151f front shift case to a top shift and then run my original top shift behind it?
‘82 Toyota RN38, mostly stock
Groundpounder17 [OP]
  • Male Posts: 99
Re: Transmission swap questions: L45 to R151f
« Reply #1 on: Feb 16, 2021, 04:39:03 PM »
Anyone?
  • Male Posts: 99
« Reply #2 on: Feb 23, 2021, 06:38:12 AM »
Im going to look at a R151f, transfer case, and bellhousing.  Can anyone advise me on what I should be looking for to make sure it is rebuildable?
OVRAROK
  • Turtle Points: 26762
  • Male Posts: 3,514
  • Member since Dec '10
« Reply #3 on: Feb 23, 2021, 06:55:44 AM »
With the R151F.. you will leave the forward shift tcase on it,( only using the crawl box) then you'll need a 23 spline adapter. Then you'll need to source a 23 spline top shift transfer case for the rear. If your planning on running the 4.7 gears in the rear box. Just make sure you order the 23 spline set..
  • Male Posts: 99
« Reply #4 on: Feb 23, 2021, 06:57:32 AM »
Thanks for the reply.  I do plan to use my current top shift case behind it with 4.7 gears.
Anything in particular I should be looking out for to make sure the transmission and T-case is rebuildable or anything to look out for?
OVRAROK
  • Male Posts: 3,514
« Reply #5 on: Feb 23, 2021, 07:22:33 AM »
The first thing I would look at is the bellhousing..only the r151f has a hole, about 3" in diameter on bottom of bellhousing.. no hole, not a true r151f bellhousing.. unfortunately it's hard to see the condition of the gears without splitting it apart. Check all the threads.. being aluminum its easy to mess them up..
OVRAROK
  • Male Posts: 3,514
« Reply #6 on: Feb 23, 2021, 07:26:28 AM »
If it comes with a shifter, I'd put in every gear and rotate the input.. good luck...
ameadows77
  • Turtle Points: -24
  • Member since Mar '21
  • rusty shitbox
« Reply #7 on: Sep 23, 2021, 08:57:25 AM »
Did you ever get this trans and get it put in your truck? I can't find a G/W trans anywhere around me so this may be an easier option
83 SR5 Longbed
  • Male Posts: 99
« Reply #8 on: Apr 05, 2022, 04:45:52 PM »
I did not get it.  It fell through.
Last post Aug 27, 2010, 09:02:18 PM
by 4x4yota
Last post Sep 12, 2010, 11:22:54 PM
by GreenYoterKrawler
Last post Jan 15, 2014, 07:20:26 PM
by 81 yota
Last post Jun 04, 2017, 12:51:21 AM
by MrFatEggs
Last post Feb 03, 2018, 05:54:41 PM
by Osage1978
