Author Topic: My 3rz Swap in my 87 P/U.  (Read 20063 times)
  • Online Silver Turtle Award
  • Turtle Points: 26762
  • Male Posts: 3,514
  • Member since Dec '10
Re: My 3rz Swap in my 87 P/U.
« Reply #60 on: Nov 28, 2018, 12:48:40 PM »
I went to mechanical gauges.. my truck runs at about 185° F.
300k
  • Turtle Points: 3744
  • Male Posts: 623
  • Member since Jun '15
  • GREEN NAME MAN BAD!
    • Please ban me!
          OK!
      I am banned!
« Reply #61 on: Nov 28, 2018, 02:21:31 PM »
Trying to get a reading from the stock gauge is like trying to get temperature from a clock. Thing is about useless as far as I'm concerned. At start up it's reading as operating temperature. at operating temperature, it's reading operating temperature. Aired down to 9PSI going 65 down the highway it's still dead center even though my DSM gauge is reading 200+.
epantano [OP]
  • Turtle Points: 275
  • Member since Aug '16
« Reply #62 on: Nov 28, 2018, 02:25:50 PM »
Gotcha. Well I ordered an ob2 Bluetooth module. It says I can get a temp reading from it. Not sure if it will work with this but hopefully.
This way I'll have all digital tach, temp etc. I
Sent from my Nexus 6 using Tapatalk
EASYRYDERDANGER
  • Turtle Points: 1856
  • Male Posts: 215
  • Member since Jul '06
« Reply #63 on: Nov 28, 2018, 08:39:23 PM »
It will capture all generic ob2 data, which includes temperature
epantano [OP]
« Reply #64 on: Dec 04, 2018, 12:47:39 PM »
So the tube that goes off the charcoal canister is leaking gas now?? What could this be?? My canister makes a weird buzz ever once in a while, I unplugged all the electrical and it still does it. What the heck could this be?
« Last Edit: Dec 04, 2018, 01:03:26 PM by epantano »
epantano [OP]
« Reply #65 on: Dec 04, 2018, 01:23:02 PM »
Okay so I've read up a good bit. I tried to open the gas cap and definitely had good pressure. But the dripping didn't stop. I guess the buzzing is normal. However has should not leak from the air  drain hose.
Do I need to replace the canister?
epantano [OP]
« Reply #66 on: Dec 04, 2018, 02:47:00 PM »
Okay so I pulled the return line from the canister and then replaced it. It seemed to have some back pressure when I first pulled it off. He pressure came from the tank. After I pulled this line the dripping has stopped.
Do I have a faulty canister? Seems so odd to me. I'll have to keep checking on it. But this is the first time it happened. Maybe has something to do with the gas tank being full as I normal just throw in whatever cash I have at the time and never really fill it up.
epantano [OP]
« Reply #67 on: Dec 09, 2018, 11:46:19 AM »
Im going crazy on this one, whenever it gets warm, that air tube dumps out over 20 oz of gas.... I have it catching it but wtf is this??
Do i need a new canister?
IS it possible i have the return and evap lines switched? How would i know if i did?
 :confused: :confused:
  • Male Posts: 3,514
« Reply #68 on: Dec 09, 2018, 11:57:16 AM »
When I did my swap, I labeled hoses, then followed back to tank. You could try swapping them  :dunno:
epantano [OP]
« Reply #69 on: Dec 09, 2018, 02:22:03 PM »
Yes just tried that, but now the sun is hiding and it always slows down when the sun isnt out. Its still dripping slowly, not sure if that was still just left in the rubber line or not.
What would happen if they were switched? I didn't seem to notice any issues until I filled up my tank. Maybe I overfilled? But I just waited for the pump to click and didn't keep going.
  • Male Posts: 3,514
« Reply #70 on: Dec 09, 2018, 02:40:05 PM »
Tomorrow, I'll chase lines down. Are you using the 87 fuel tank
epantano [OP]
« Reply #71 on: Dec 09, 2018, 02:48:36 PM »
Yes sir. All p/u stuff is from an 87 22re setup.
  • Male Posts: 3,514
« Reply #72 on: Dec 09, 2018, 02:54:34 PM »
My 4runner is 87. I'm sure they are the same. As far as fuel/return/vent on tank
gnob
  • Turtle Points: 486
« Reply #73 on: Dec 10, 2018, 12:01:20 PM »
You should not have raw fuel in the canister. You either have a plumbing issue or bad canister.  Typically fuel in canister is caused by overfilling tank.
hold this. . .
epantano [OP]
« Reply #74 on: Dec 10, 2018, 07:58:23 PM »
a
I suppose it possible that it was overfilled, I pumped normally and let it click off, (not topping off) I think i may have had return lines mixed up, but not really sure since it runs all the same either way. It will only leak when It is over 70 degrees / sun is out and truck is off.
epantano [OP]
« Reply #75 on: Dec 13, 2018, 01:44:06 PM »
my gauge also sits slightly above half way(185). one of the beauties of the swap is the obd port which allows for monitoring and diagnostics. I use the torque pro app along with gaia/avenza gps for offline mapping
My truck sits about 210(using OB2 scanner), is that to warm? Im pretty sure I bought a 180 degree t Stats... Anyhow i have no fan shroud so that could be part of it.
It sounds like you have your vent and return lines mixed up. The return line drops down to the bottom of the tank so if they were mixed up you would be venting liquid gas. The system is designed to vent fumes out the drain tube when the engine is off and there is excessive pressure in the tank, otherwise it's venting fumes into the intake when the engine is running. It's not very easy to flood an evap canister that is under the hood compared to newer vehicles that have them mounted near the gas tank when (over)filling. If you want to compare your connections, I'm in the San Diego area.
I've switched the lines and ran the truck for a good while just to try to use up some gas. I'm thinking I had the lines mixed up and I had my tank overfilled, guess I'll just have to be careful at the gas station when filling. Not a drop has come out of the vent line since and we had a few warm days, which is when it typically happens.
Also Id love to come check out your rig sometime, just to see what you have done to it. Not that I could really drive my rig anywhere yet, still waiting on my PS box to arrive.
  • Male Posts: 3,514
« Reply #76 on: Dec 13, 2018, 01:52:31 PM »
My truck runs all day at 187 degrees F.
epantano [OP]
« Reply #77 on: Dec 13, 2018, 02:18:05 PM »
I did get a few things done today!  :beer:
Got my spare tire mounted on my extra rim finally...
I also got my pitman arm all figured out! I picked up one from a 3rd Generation Toyota P/U 2WD with power steering. Its perfect option that's in between a flat arm and the 3/4" less the stock drop Sky arm. Part#45411-35320 You will have to file 2 splines into it. Super easy using a triangle file.
I ordered it from https://partsouq.com. I was a little skeptical at first since it was half the price of others, but It arrived pretty quick.
So I am running too hot? Should I replace the Tstat? Any other recommendations? I have a new radiator, just flushed and new coolant.
Maybe I need to try to make a fan shroud that would fit.
  • Male Posts: 3,514
« Reply #78 on: Dec 13, 2018, 02:22:21 PM »
Are you running 3rz fan..  I'm using 22re fan and fan clutch, with stock 22re fan shroud.
epantano [OP]
« Reply #79 on: Dec 13, 2018, 02:24:28 PM »
Yes I have the 3rz fan, I thought It would cool better since its WAY bigger.
  • Male Posts: 3,514
« Reply #80 on: Dec 13, 2018, 02:28:00 PM »
How's your fan clutch? Also I'm running aluminum radiator. With as shroud. I was going to go 3rz fan route. But when I saw it wouldn't fit into shroud, I decided on 22re fan,fan clutch, and shroud
epantano [OP]
« Reply #81 on: Dec 13, 2018, 02:38:13 PM »
Im using the RZ clutch, Seems pretty good, yes same here 3 core all aluminum as well. I might just try to make one see if it will make a difference. Or maybe add a pusher fan on the front.
  • Male Posts: 3,514
« Reply #82 on: Dec 13, 2018, 02:40:24 PM »
I think a shroud will drop temps by 10°
300k
  • Male Posts: 623
    • Please ban me!
          OK!
      I am banned!
« Reply #83 on: Dec 13, 2018, 03:16:00 PM »
Didn't notice a difference on the temp gauge with or without a shroud.
  • Male Posts: 3,514
« Reply #84 on: Dec 13, 2018, 03:45:18 PM »
What gauge are you reading off. The stock gauge in cluster. Or aftermarket.
300k
  • Male Posts: 623
    • Please ban me!
          OK!
      I am banned!
« Reply #85 on: Dec 13, 2018, 04:09:26 PM »
Autometer spek pro. Cluster gauge is useless
epantano [OP]
« Reply #86 on: Dec 13, 2018, 04:20:14 PM »
I have an ob2 unit that's giving me live temperature. The gauge itself only reads half. But yes useless for actually temp.
redneckcustoms13
  • Turtle Points: 7674
  • Male Posts: 2,513
  • Member since May '15
« Reply #87 on: Dec 13, 2018, 04:31:58 PM »
I only have an electric fan on a thermostat switch and mine never breaks 187-188. I suggest to put your 22r shroud and fan back on or go electric.
01 double cab hunting truck
06 tacoma street truck
epantano [OP]
« Reply #88 on: Dec 13, 2018, 04:38:16 PM »
Is it possible I just have throughly bleed it?
epantano [OP]
« Reply #89 on: Dec 13, 2018, 05:38:41 PM »
that's a great find on the 2wd arm. i am currently using an 80 series arm which is working well but i like that the 2wd arm is a little shorter with less drop. i just looked up the part on your link, you got the last one i guess(showing 0 in stock).
Yes, it worked out perfect for my application and was cheaper than the SKY arms. Another place I saw one was on Ebay, it was used but it was cheaper.
Too bad it is out of stock now that makes it about the same price as sky's new.
The 80 series arm is a little longer than a stock IFS arm right? So in effect, you gain a faster turn, but it would be slightly more difficult. For some they may run into their steering arms hitting.
Last post Oct 23, 2009, 09:12:54 PM
by I.D.G.A.F
Last post Jun 06, 2009, 11:45:35 PM
by toyotanner
Last post May 01, 2011, 09:20:43 PM
by jrock
Last post Jan 12, 2012, 05:18:31 PM
by 4RunnerChevy
Last post Oct 02, 2012, 09:07:38 PM
by Rocksurfer
