1KZ-te
Started by dewiseman, October 22, 2017, 07:51:35 PM
dewiseman
are there any  1kz guys on here?
LittleSteve
Refusing to fit in or comply.
Easy is not worth anything.
helipilot77
Quote from: dewiseman on October 22, 2017, 07:51:35 PM
Been a long time since we talked Dennis. Are you back in Washington?
cavey
yes i must admit to owning one
own a 1989  LN106r diesel with a 1KZ-T 3 litre turbo diesel  bolted to a imported R151F gearbox with snorkel Rancho springs & shocks & Detroit lockers F & R & 11x 32  cooper sst ultimate dual transfer cases 130 litre fuel tank   full floating disc brake rear end
dewiseman
Bringing it back to life.
Both this thread and my 95 4Runner  1KZ-te
My 4r has set most of the last year due to radiator problems.
Finally bit the bullet, and picked up a Griffin radiator that fits well. It is a Side flow radiator and I'm getting a brace made for the radiator that runs from frame to frame.
Should I have the brace welded directly to each frame (rigid) or make it bolt to the frame?  Will it make any difference either way??
Thanks for your responses.
helipilot77
Factory mounts often include some sort of rubber isolators although Toyota didn't use them in the originals on the 4runners or trucks. Will probably be fine hard mounted to the chassis.
dewiseman
Thanks Nate.  My original thoughts were to use a piece of aluminum channel wide enough for the rad to sit down into and have the radiator sit on some rubber feet from an air compressor.  This guy  says he tried mounting his radiator in rubber when he did his LS swap.  He said it was so noisy
he took it back out and hard mounted it.  I'm not convinced yet to abandon the rubber vibration feet.
AV8R TRANSPORT
OLD TREAD,, but yes I have a new to me 1KZ-TE in a 1994 forerunner ,, known as a Surf.
it was birthed in Japan, immediatly adopted in Austrailia, migrated to Canada,, then south to America ( Vermont) and now I have it in San Diego CA ... YEAH! pretty happy about that
helipilot77
Very nice! congratulations on your acquisition.
