0 Members and 13 Guests are viewing this topic.
Just triple-checking here - a V6 third member will work, right? Found an '88 V6 truck parting out and it has a pretty clean interior in it, too and I've been wanting to replace my interior.
Go hi-pinion if you can.
lol, somebody needs to put one in the rear axle just so I can see what it looks like. HA HA HA!!!!!!!!!!!!any pictures?
I HAVE INSTALLED MANY V6 3RDS WITH NO GRINDING REQUIRED.THE ONLY PROBLEM I HAVE SEEN WHEN CHANGING TO V6 IS THE DRIVE SHAFT FLANGE. FLANGE IS NOT INTERCHANGEABLE DUE TO PINION SIZE.THERE ARE MULTIPLE FLANGE BOLT PATTERNS. THIS CAN BE SOLVED BY INSTALLING A NEW FLANGE THAT HAS MULTIPLE PATTERNS DRILLED INTO IT. HOPE THAT HELPS.
I may have a 4.10 4Cyl third at home?
PM Sent!
It's from a front, not sure it really matters?
If it is standard pinion then it does not.
Started by SWAMPER Engine
Started by Jared Parts Wanted
Started by Huhwhye Engine
Started by fade Parts For Sale
Started by Native Warrior Axle/Differential/Steering
