Author Topic: Solid axle 3rd Member Interchange?  (Read 14198 times)
Plainview
  • Turtle Points: 175
  • Member since May '14
« on: May 07, 2016, 08:47:38 PM »
Been doing some searching and pretty sure I know the answer, but would appreciate it if one of you knowledgeable folks would confirm or correct for me.
All 4WD solid axle 3rd members interchange from '79 -'95.   Is that correct?
'84 Xtra Cab Project:
http://board.marlincrawler.com/index.php?topic=100651.new#new
Parts Wanted:
- Un-cracked dash pad (do they exist?)
  • Turtle Points: 1174
  • Male Posts: 5,060
  • Crawlin with Marlin
Re: Solid axle 3rd Member Interchange?
« Reply #1 on: May 07, 2016, 08:53:30 PM »
That sounds right. My 85 rear third is in my 89 rear housing so I know it goes that far at least.
:)bestgen4runner
  • Turtle Points: 2120
  • Male Posts: 1,796
  • Member since Mar '16
« Reply #2 on: May 07, 2016, 08:55:45 PM »
Yes that is correct.
Even the newer ones fit and function.
I am 1/5th of Perfect Fit
:)bestgen4runner
  • Male Posts: 1,796
« Reply #3 on: May 07, 2016, 08:56:46 PM »
Go hi-pinion if you can.
Plainview [OP]
« Reply #4 on: May 07, 2016, 09:00:43 PM »
thanks!
bestgen4runner - could you be more specific?  What do you mean by "newer" ones?  Specific years?  And are they a direct bolt-in without having to change anything else?
Also, what years/applications would have a high pinion?
For the moment I need to find a 3rd I can swap in with no hassles as I broke my ring gear and need the truck back on the road ASAP.
Also - the front and rear solid axles are the same, aren't they?  In other words, I could put a rear third from a later model truck into the front solid axle of my '84... right?
Parts Wanted:
:)bestgen4runner
  • Male Posts: 1,796
« Reply #5 on: May 07, 2016, 09:07:46 PM »
If it's a 8" diff front or rear it will work for what you at after.
Don't pay more than $50
You need to know your gear ratio,
Did you break the rear?
Why not just replace ring and pinion only.
Plainview [OP]
« Reply #6 on: May 07, 2016, 09:22:40 PM »
Easiest and fastest way to get this fixed is going to be to pull a third member from a wrecking yard or truck someone is parting and bolt the whole thing in.
I don't have the tools/knowledge to set up the gears so would have to pay someone to do that, plus the gears themselves aint cheap and if I'm going to be rebuilding a third member then I'm going to want to put a locker or tru trac in and change the gear ratio too.
Just need to get this truck back on the road in the next few days so swapping the entire 3rd is the easiest and probably cheapest way to do it, though I bet I'll have to pay more than $50.  Aint nothing cheap in this neck of the woods.
Gears are 4.10s.
Parts Wanted:
:)bestgen4runner
  • Male Posts: 1,796
« Reply #7 on: May 07, 2016, 09:38:00 PM »
What neck of the woods we talking about.
Maybe I can help
Plainview [OP]
« Reply #8 on: May 07, 2016, 09:39:13 PM »
Seattle
Parts Wanted:
:)bestgen4runner
  • Male Posts: 1,796
« Reply #9 on: May 07, 2016, 09:42:23 PM »
I'm in maple valley
Toyota master tech for 13 years
What is your gear ratio ?
Plainview [OP]
« Reply #10 on: May 07, 2016, 09:53:19 PM »
PM sent.
Parts Wanted:
Plainview [OP]
« Reply #11 on: May 08, 2016, 09:26:15 PM »
Just triple-checking here - a V6 third member will work, right?
Found an '88 V6 truck parting out and it has a pretty clean interior in it, too and I've been wanting to replace my interior.
Parts Wanted:
1985CRAWLER
  • Turtle Points: 267
  • Male Posts: 1,163
  • Member since Feb '13
  • Backyard Built
« Reply #12 on: May 08, 2016, 09:42:54 PM »
If you don't already have a v6 3rd in it you are gonna have to grind a little bit off the sides of the housing where the diff goes in to make it fit , I did this with my my 87 ifs rear, but once you clearance the housing you can run v6 3rds or 4cly
:)bestgen4runner
  • Male Posts: 1,796
« Reply #13 on: May 09, 2016, 07:28:55 AM »
I HAVE INSTALLED MANY V6 3RDS WITH NO GRINDING REQUIRED.
THE ONLY PROBLEM I HAVE SEEN WHEN CHANGING TO V6 IS THE DRIVE SHAFT FLANGE. FLANGE IS NOT INTERCHANGEABLE DUE TO PINION SIZE.
THERE ARE MULTIPLE FLANGE BOLT PATTERNS. THIS CAN BE SOLVED BY INSTALLING A NEW FLANGE THAT HAS MULTIPLE PATTERNS DRILLED INTO IT.
HOPE THAT HELPS.
mudmaster
  • Online The 2.5K Group
  • Turtle Points: 3715
  • Male Posts: 2,854
« Reply #14 on: May 09, 2016, 07:44:40 AM »
No yelling Chris  :yikes:
Time to go wheelin!
:)bestgen4runner
  • Male Posts: 1,796
« Reply #15 on: May 09, 2016, 09:25:18 AM »
My bad
My work computer requires all caps. lol
SqWADoosh
  • Turtle Points: 10966
  • Male Posts: 2,417
  • Member since Oct '14
« Reply #16 on: May 09, 2016, 10:15:09 AM »
In the front. Should specify this.
:)bestgen4runner
  • Male Posts: 1,796
« Reply #17 on: May 09, 2016, 10:25:06 AM »
lol,
somebody needs to put one in the rear axle just so I can see what it looks like. HA HA HA!!!!!!!!!!!!
any pictures????
  • Turtle Points: 26739
  • Male Posts: 3,523
  • Member since Dec '10
« Reply #18 on: May 09, 2016, 11:33:28 AM »
lol,
any pictures????
Marlin has tried a couple times
Plainview [OP]
« Reply #19 on: May 09, 2016, 11:40:11 AM »
HOPE THAT HELPS.
BIG HELP!  LOL
Thanks for the warning, I probably would have got it home, installed it, and then been really pissed when I went to hook up the driveshaft.
So that leads to the next question - are the U-joints the same between 4-cyl and 6-cyl?  If they are, I can just take the yoke off the end of the V6 driveshaft and put it on my 4-cyl driveshaft so it'll mate with the pinion flange.
Still looking for a replacement 3rd member. That ad I referenced above was posted by some dummy who didn't include any contact info.  On lunch break now, time to start calling wrecking yards.
Parts Wanted:
Plainview [OP]
« Reply #20 on: May 09, 2016, 12:27:41 PM »
Where do you find these things for $50???
I've called a bunch of yards today.  Only a few actually bothered to answer their phones and of those only 410 Auto Wrecking down in Buckley has one and they want $350 for it...
Parts Wanted:
:)bestgen4runner
  • Male Posts: 1,796
« Reply #21 on: May 09, 2016, 01:06:25 PM »
I get them from work now and then. I sell them on craigslist for $50 for open diff 4cyl. more for v6.
apparently the wrecking yards are crazy.
Try Fred's in Enumclaw. small yard but they sell for cheep. other wise its craigslist.
Don't be afraid to dicker on the price.
I will start hunting craigslist for you.
Plainview [OP]
« Reply #22 on: May 09, 2016, 01:24:23 PM »
That would be great if you could find something!   I've done what I believe is a pretty thorough CL search and there's just nothing out there right now.  One '88 V6 truck in Stanwood but that's the guy who didn't include any contact info.  He's probably wondering why no one's calling him... LOL   :hammerhead:
Sounds to me like you've been selling them too cheap...   :greengrin:
Parts Wanted:
mudmaster
  • Male Posts: 2,854
« Reply #23 on: May 09, 2016, 01:35:09 PM »
I may have a 4.10 4Cyl third at home?
Time to go wheelin!
:)bestgen4runner
  • Male Posts: 1,796
« Reply #24 on: May 09, 2016, 01:38:10 PM »
There you go
mark might be able to save your day!!!!!!
Plainview [OP]
« Reply #25 on: May 09, 2016, 03:02:20 PM »
PM Sent!
Parts Wanted:
mudmaster
  • Male Posts: 2,854
Time to go wheelin!
mudmaster
  • Male Posts: 2,854
« Reply #27 on: May 09, 2016, 04:32:29 PM »
It's from a front, not sure it really matters?
Time to go wheelin!
SqWADoosh
  • Male Posts: 2,417
« Reply #28 on: May 09, 2016, 04:47:33 PM »
If it is standard pinion then it does not.
mudmaster
  • Male Posts: 2,854
« Reply #29 on: May 09, 2016, 04:58:56 PM »
I  was mostly saying it cuz it was used in the front so it was broken in that way.
Time to go wheelin!
Last post Jun 11, 2004, 02:31:16 PM
by SWAMPER
Last post Jan 05, 2005, 04:41:12 PM
by 19801981
Last post Jan 25, 2005, 09:20:38 PM
by MidgetMike
Last post Jul 24, 2015, 05:28:23 PM
by kneedownnate
Last post May 02, 2019, 08:25:49 AM
by 83_P/U_4x4
