Author Topic: Tacoma power steering issue  (Read 3954 times)
KDC
  • Turtle Points: 153
  • Male Posts: 180
  • Member since May '05
  • Axle Breaking Goodness
« on: Jan 31, 2016, 06:05:48 PM »
Hey, guys.
I have an 04 Tacoma in which I'm having trouble with the power steering. I started the truck one morning to the pump screaming, but still had power assist. Fluid level was good and there appeared to be no leaks. Then I lost power assist.
The following is what I have done:
1. Replaced the pump- no improvement
2. Replaced the rack and pinion - no improvement
3. Replaced feed line - no improvement
4. Replaced the pump again - no improvement
5. Replaced return line - no improvement
6. Replaced the pump again - no improvement
At this point, I'm not sure what to do. I'm doubtful that it is a component failure, but don't know what it could be.
How long would you expect the pump to stop whining and power assist to return while bleeding the system?
Also, does anyone have any thoughts on what to do next?
I appreciate anything you can recommend!
  • Turtle Points: 26739
  • Male Posts: 3,522
  • Member since Dec '10
Re: Tacoma power steering issue
« Reply #1 on: Jan 31, 2016, 06:11:44 PM »
does the steering work now, with the exception of the scream. had a buddy had problem, ended up being ac idler pulley bearing
KDC [OP]
  • Male Posts: 180
« Reply #2 on: Jan 31, 2016, 07:54:39 PM »
No, still no power assist. As I'm working the wheel back and forth during the bleeding, the pump screams bloody murder. Is there an adjuster of some sort on the rack and pinion?
  • Male Posts: 3,522
« Reply #3 on: Jan 31, 2016, 08:09:26 PM »
what about the filter screen under the reservoir, have you tried cleaning it? also are you bleeding with front end off the ground? have you looked into reservoir afterward, looking for bubbles?
redneckcustoms13
  • Turtle Points: 7674
  • Male Posts: 2,513
  • Member since May '15
« Reply #4 on: Feb 01, 2016, 08:00:29 AM »
What rok said. The beat way to bleed a steering system especially on these trucks is with the front off the ground. Do not start the engine until you are getting no more bubbles in the reservoir while working the wheel lock to lock.
01 double cab hunting truck
06 tacoma street truck
KDC [OP]
  • Male Posts: 180
« Reply #5 on: Feb 02, 2016, 06:35:05 AM »
I haven't cleaned the filter in the reservoir. I'll try that. I've had tiny bubbles in the reservoir while bleeding. I would have expected more or larger bubbles and have only needed to refill the reservoir once, right after start-up, prior to bleeding.
Are you saying to bleed it with the engine off?
Toyotadon
  • Turtle Points: 426
  • Male Posts: 267
  • Member since Dec '08
« Reply #6 on: Feb 02, 2016, 09:31:02 AM »
Yes, to bleeding with the engine off.  You can get most of the air out of the system by turning the wheel back & forth with the front end off the ground.  Hold it at full left or right for 30 seconds each time, many bubbles will be rising when you do this.  If you start the engine with air in the system, it just mixes with the fluid and makes it harder to get out.
KDC [OP]
  • Male Posts: 180
« Reply #7 on: Feb 02, 2016, 11:22:04 AM »
Cool. How long would you expect to have to bleed with the engine off?
Toyotadon
  • Male Posts: 267
« Reply #8 on: Feb 02, 2016, 03:42:29 PM »
Go back and forth several times. Patience is your friend, it also helps to have a friend turning the wheel while you watch for bubbles, or vice versa.
KDC [OP]
  • Male Posts: 180
« Reply #9 on: Feb 02, 2016, 05:48:40 PM »
Ovrarok wins! It was a dirty, clogged filter in the reservoir. Thanks for everyone's input and help.
Last post Oct 05, 2008, 12:32:53 PM
by Pat
Last post Aug 14, 2012, 10:38:59 PM
by Dingman.
Last post Aug 28, 2015, 06:57:52 PM
by spuds015
Last post Jan 03, 2017, 10:29:38 PM
by ChadStich
Last post Jul 24, 2019, 02:51:07 PM
by MrBooyay
