Author Topic: PSC Power Steering Pump Cavitation Issue  (Read 8291 times)
ChadStich
  • Turtle Points: 1021
  • Male Posts: 118
  • Member since Jul '15
« on: Dec 29, 2016, 12:00:02 AM »
I Put a PSC TC pump on my truck and I'm having issues with cavitation. I put the front up on jack stands and did the normal bleeding procedure and it worked great. No more wine and the pump was silent. Started driving it and I made it a few miles and it started to wine and cavitate. Took it back home re bleed it, took it for a drive and same thing. Ive done this multiple times and alway the same result. Does anyone have any idea or experience with what the problem could be? I checked all the lines for leaks and I can't find any.
Here are some pictures of the setup.
94 2wd extra cab sas, 3rz, 4.30 e-lockers f/r, dual stock cases with marlin adapter, longs, 35s, RUF, Chevy 63's
http://board.marlincrawler.com/index.php?topic=99269.0
Ritchie
  • Turtle Points: 539
  • Male Posts: 265
  • Member since May '13
  • Ritchie
Re: PSC Power Steering Pump Cavitation Issue
« Reply #1 on: Dec 29, 2016, 05:22:11 AM »
Can you provide a pic of the pump & reservoir together?
I had the same issue and found the fill level mark inside the reservoir was below the low pressure input on the pump.  I raised the reservoir and it cured 90% of the whine.
When I change the fluid, I'll be using Valvoline Pro V series power steering fluid.  Doesn't foam like other products, creating whine.
Good luck.
'03 Step side Pre-runner, F/R 4WU 3 linked, F/R Diamond axles, F/R ARB's w/5.29's, F/R Fox 12" CO's, ShrockWorks front bumper, self made rear bumper, WARN M8000S w/ remote, 4.7 Inchworm Lefty, MC sliders that hold air & a bunch of other stuff.
ChadStich [OP]
  • Male Posts: 118
« Reply #2 on: Dec 29, 2016, 09:50:19 AM »
Here is a couple pictures. The first one shows the height differences in the lines.
megaphoneman
  • Turtle Points: 677
  • Member since Nov '04
« Reply #3 on: Dec 29, 2016, 01:13:22 PM »
Do you have a ram on it?
ChadStich [OP]
  • Male Posts: 118
« Reply #4 on: Dec 29, 2016, 02:10:23 PM »
No ram on it just the pump for now.
megaphoneman
« Reply #5 on: Dec 29, 2016, 02:40:34 PM »
thats part of your problem.. they pump so high that they do that..i pulled my ram off and it quickly got super hot and would cavitate.. you need a tad more height for sure but the psc pumps don't like not having a ram i guess..
Ritchie
  • Male Posts: 265
  • Ritchie
« Reply #6 on: Dec 29, 2016, 03:19:51 PM »
I noticed the height difference of the fittings on your reservoir.  Both of mine are at the bottom... not sure if that matters.
ChadStich [OP]
  • Male Posts: 118
« Reply #7 on: Dec 29, 2016, 03:53:56 PM »
Mine isn't getting hot at all lucky it just makes a whole bunch of noise. Ill be getting a ram soon though so Maybe that will help.
I see that. I might have to build another reservoir and but them both at the bottom.
Ritchie
  • Male Posts: 265
  • Ritchie
« Reply #8 on: Dec 29, 2016, 04:15:38 PM »
... come to think of it, if your top outlet on the reservoir is feeding the pump, that could be an issue in that there is a chance of the pump pulling air instead of fluid.  Think of your truck on an angle, fluid will go to one side or the other.
Anyway, just a thought.
ChadStich [OP]
  • Male Posts: 118
« Reply #9 on: Dec 29, 2016, 04:57:31 PM »
The bottom hose is the feed line the top is the return coming from the cooler. Its just the way the picture is taken. But like you said maybe the fluid level is below the return and causing it to aerate the fluid causing the cavitation. The return is pretty close to the top but I think I can get the fluid level past it without it overflowing. Im going to give it a shot.
Ritchie
  • Male Posts: 265
  • Ritchie
« Reply #10 on: Dec 30, 2016, 05:17:40 AM »
My Howe system is pressurized as well, not sure if that changes things up.
I'll get a better photo of the reservoir once the sun is up.
Ritchie
  • Male Posts: 265
  • Ritchie
« Reply #11 on: Dec 30, 2016, 03:34:50 PM »
Here are a couple pics for you.
ChadStich [OP]
  • Male Posts: 118
« Reply #12 on: Jan 01, 2017, 05:11:43 PM »
Cool thanks. I might just build a new one
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
« Reply #13 on: Jan 03, 2017, 06:23:25 PM »
The best fluid you can run.
ChadStich [OP]
  • Male Posts: 118
« Reply #14 on: Jan 03, 2017, 10:29:38 PM »
thats what I'm running
Last post Oct 05, 2008, 12:32:53 PM
by Pat
Last post Aug 14, 2012, 10:38:59 PM
by Dingman.
Last post Aug 28, 2015, 06:57:52 PM
by spuds015
Last post Feb 02, 2016, 05:48:40 PM
by KDC
Last post Jul 24, 2019, 02:51:07 PM
by MrBooyay
