Author Topic: Tire / gear calculator  (Read 3340 times)
David
  • Turtle Points: 218
  • Male Posts: 263
  • Member since Jan '03
  • I love Marlin Crawler!
« on: Jul 03, 2011, 11:29:11 AM »
I put on bigger tires and needed a formula to calculate what new gears I need to compensate, so here is what I found....
A simple tire / gear calculator is to multiply your new tire diameter and your old gear ratio, then divide by your old tire diameter.
example: 30 inch tires and 3.50 gears, and now you put on 35 inch tires: (35 x 3.50) divided by 30 = 4.08 gear ratio to compensate.
If this has been posted before, sorry.
twistedtoy92
  • Turtle Points: -255
  • Male Posts: 3,781
  • Member since Dec '06
  • NFM Customs
Re: Tire / gear calculator
« Reply #1 on: Jul 03, 2011, 12:56:03 PM »
what size did you put on?
bigarms23
  • Turtle Points: 111
  • Male Posts: 2,897
  • Member since Jun '07
« Reply #2 on: Jul 03, 2011, 01:22:30 PM »
x2 but either 488s or 529s are good
crazykooter
  • Turtle Points: -369
  • Male Posts: 1,418
  • Member since Apr '09
  • Located in Byron, CA
« Reply #3 on: Jul 03, 2011, 02:36:38 PM »
Just fyi here is a link to a gear ratio calc.  http://www.grimmjeeper.com/gears.html
Tho both post are correct.
David [OP]
  • Male Posts: 263
« Reply #4 on: Jul 06, 2011, 08:26:53 PM »
I ended up with 33/12.50/15's I like them but need to re-gear.
 I'll be looking for 4.56,s or 4.88's soon.
Example given was not for my rig, they are ford spec's I believe.
Anybody else running a pretty much stock first gen with 33's and a gear change and how did it affect your mileage and performance?
bigarms23
  • Male Posts: 2,897
« Reply #5 on: Jul 06, 2011, 08:54:28 PM »
go with 488s
twistedtoy92
  • Male Posts: 3,781
  • NFM Customs
Last post Mar 05, 2008, 06:16:40 PM
by toyotamobing
Last post Jul 01, 2008, 07:42:27 PM
by NorCalToy
Last post Oct 17, 2010, 11:22:02 AM
by 12GA.YOTA
Last post Mar 11, 2013, 07:13:25 PM
by H8PVMNT
Last post Aug 24, 2015, 09:52:17 AM
by mdtrail-toy
