Author Topic: Clutch Problems  (Read 2117 times)
blackdiamond
  • Turtle Points: 1174
  • Male Posts: 5,057
  • Member since Dec '03
  • Crawlin with Marlin
Clutch Problems
« on: Aug 16, 2009, 11:44:43 AM »
Yesterday as I was driving home I noticed the clutch pedal starting to feel squishy and soft.  I started having difficulty getting it to shift at times and got stuck at a stop light once because it simply wouldn't go into first.  I never heard any grinding and when I got home I confirmed that the clutch master cylinder resevoir was essentially empty.  I did see some fluid on the front driveshaft, but the master cylinder area appears to be dry and the cylinder mounted to the bell house is also dry.
Any idea where the fluid is going?  :dunno:
highridin4x4
  • Male Posts: 237
  • Member since Oct '06
Re: Clutch Problems
« Reply #1 on: Aug 16, 2009, 11:50:21 AM »
I had on that leaked into the drivers compartment and ran down behind my floor covering.
Scott
Steve_925
  • Turtle Points: -86
  • Male Posts: 1,876
  • Member since Feb '07
  • F***in catalina wine mixer
Re: Clutch Problems
« Reply #2 on: Aug 16, 2009, 12:46:16 PM »
Scott
see if your carpet is damp.
UA 342
STEAMFITTERS
Joey88RUNR
  • Turtle Points: -23
  • Male Posts: 1,057
  • Member since Feb '08
Re: Clutch Problems
« Reply #3 on: Aug 16, 2009, 03:53:16 PM »
yea check under your pedal, thats where mine leaked at :yesnod:
blackdiamond [OP]
  • Male Posts: 5,057
Re: Clutch Problems
« Reply #4 on: Aug 16, 2009, 05:27:40 PM »
Looks like you're all correct.  It's wet on the firewall.  Now I just need to call Toyota and confirm the part number so I can get some parts ordered from Marlin Crawler.  I've found that the 89 4Runner has some 88 parts on it so I want to be sure via VIN.
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: Clutch Problems
« Reply #5 on: Aug 16, 2009, 06:36:12 PM »
clutch master should be the same i think
zembalayan
  • Turtle Points: 254
  • Male Posts: 486
Re: Clutch Problems
« Reply #6 on: Aug 17, 2009, 07:19:43 PM »
bd,
You might want to replace your slave cylinder while you're at it.  When my slave cylinder went, it only took three weeks for the clutch master to go out.
blackdiamond [OP]
  • Male Posts: 5,057
Re: Clutch Problems
« Reply #7 on: Aug 17, 2009, 07:21:39 PM »
bd,
Both are on order as of this morning.  A few months ago I flushed the fluid when I changed the brake master cylinder and I think I cleaned too much junk out of it so now it has leaks.  The fluid in both the brakes and clutch was extremely dark and had floaties that I suspect were parts of the seals breaking down.
zembalayan
  • Male Posts: 486
Re: Clutch Problems
« Reply #8 on: Aug 17, 2009, 07:25:20 PM »
I know you'll get your money's worth out of the new parts! :biggthumpup:
abriel68
  • 85 4runner
Re: Clutch Problems
« Reply #9 on: Aug 18, 2009, 08:15:48 PM »
i have the same problem, its leaking behind the pedal, its not coming out of the slave or the master cylinder, where can i get the assembly behind the pedal? thanks alot
blackdiamond [OP]
  • Male Posts: 5,057
Re: Clutch Problems
« Reply #10 on: Aug 18, 2009, 09:01:21 PM »
The master cylinder connects to the clutch pedal, I believe, so it's your master cylinder that's leaking.
abriel68
  • 85 4runner
Re: Clutch Problems
« Reply #11 on: Aug 18, 2009, 10:53:31 PM »
should i just get the clutch master cylinder kit? or the whole thing? i checked out autozone and they have the kit wich i would believe comes with new seals or the whole master cylinder?
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
Re: Clutch Problems
« Reply #12 on: Aug 18, 2009, 10:59:06 PM »
I'd get the whole thing with a life-time warranty...........
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
abriel68
  • 85 4runner
Re: Clutch Problems
« Reply #13 on: Aug 18, 2009, 11:53:33 PM »
ok thanks alot guys,
blackdiamond [OP]
  • Male Posts: 5,057
Re: Clutch Problems
« Reply #14 on: Aug 19, 2009, 07:07:56 AM »
Get it from Marlin Crawler.  OEM quality at parts store prices.
blackdiamond [OP]
  • Male Posts: 5,057
Re: Clutch Problems
« Reply #15 on: Sep 01, 2009, 08:48:00 PM »
It took a while to get the parts, but I got the clutch fixed tonight.  It turned out to be as simple as it looked like it should be.  Marlin was out of stock on the Master Cylinder when I first ordered, but finally got one in and shipped out.
abriel68
  • 85 4runner
Re: Clutch Problems
« Reply #16 on: Oct 28, 2009, 04:48:03 PM »
got my parts in today it took maybe an hour tops to get em all in and blead, thanks alot guys.
Last post Oct 19, 2005, 07:31:40 AM
by 79coyotefrg
Last post Jan 11, 2010, 12:41:03 AM
by kneedownnate
Last post Aug 05, 2010, 06:38:10 AM
by 79coyotefrg
Last post Mar 07, 2012, 03:03:03 PM
by UndefinedTaco
Last post May 16, 2015, 01:53:20 PM
by AaronB
