Author Topic: Cooling Issues  (Read 3650 times)
jrock
  • Turtle Points: 77
  • Male Posts: 3,395
  • Member since Oct '06
  • Oodelally
Cooling Issues
« on: Jun 17, 2009, 06:34:47 PM »
I'm having a bit of a problem with my cooling.... For example:
Light driving (ie. <35mph), 1/8 on gauge.
Freeway (65-70), 1/2.
Hills, 3/4.
Thermostat is fairly new and I just flushed the system trying to fix this problem. It does not change quickly and it does not over heat. Can someone point me in the right direction.  :dunno:
*** YELLER ***
  • BIGMIKE SAID I WAS A CLOWN SO .... GUESS THATS THAT
  • Turtle Points: 314
  • Male Posts: 4,686
  • Member since Oct '05
  • USMC NO BETTER FRIEND NO WORSE ENEMY
    • Buy me a soda
Re: Cooling Issues
« Reply #1 on: Jun 17, 2009, 06:41:19 PM »
Hills, 3/4.
GO THAT WAY ------------->
<----------------NO WAIT GO THAT WAY
CRAP IM NO HELP
 :usa: :beerwhack:
except BACON
Blingn
  • Turtle Points: 155
  • Male Posts: 2,356
  • Member since May '06
Re: Cooling Issues
« Reply #2 on: Jun 17, 2009, 06:44:14 PM »
what is the issue if it is not overheating?  We need more infro mation
If you were talking about my tow rig I would say that is just about right.
*** YELLER ***
  • Male Posts: 4,686
    • Buy me a soda
Re: Cooling Issues
« Reply #3 on: Jun 17, 2009, 06:49:18 PM »
But were not talking about yer tow rig now are we  :shake: and stop following me around the board  :wave:
 :usa: :beerwhack:
except BACON
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
Re: Cooling Issues
« Reply #4 on: Jun 17, 2009, 07:29:59 PM »
Test the thermostat.   Sounds like it's stuck (somewhere between closed and fully open)
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
jrock [OP]
  • Turtle Points: 77
  • Male Posts: 3,395
  • Oodelally
Re: Cooling Issues
« Reply #5 on: Jun 17, 2009, 10:24:49 PM »
I will check that.
It's my toyota. 22re, 33's, w56, blah blah.
DeadlyPeace
  • Male Posts: 593
  • Member since Nov '07
  • HEAVILY medicated for your protection!
    • ToyotaOffRoad
Re: Cooling Issues
« Reply #6 on: Jun 17, 2009, 10:25:25 PM »
Did you make sure to burp it?
I REJECT YOUR REALITY AND SUBSTITUTE MY OWN
Never let people think you’re a horrible person and always keep the heart of a young child…
       ...I prefer mine in a jar on my desk.
3 CAT scans a MRI and some time with the shrink and it's comfirmed. I'm just not right in the head.
Global Moderator for www.ToyotaOffRoad.com
jrock [OP]
  • Turtle Points: 77
  • Male Posts: 3,395
  • Oodelally
Re: Cooling Issues
« Reply #7 on: Jun 17, 2009, 10:25:43 PM »
CRAP IM NO HELP
 :usa: :beerwhack:
Weirdo.
jrock [OP]
  • Turtle Points: 77
  • Male Posts: 3,395
  • Oodelally
Re: Cooling Issues
« Reply #8 on: Jun 17, 2009, 10:26:08 PM »
Yes.
DeadlyPeace
  • Male Posts: 593
    • ToyotaOffRoad
Re: Cooling Issues
« Reply #9 on: Jun 17, 2009, 10:30:01 PM »
Then I'd say thermostat or clutch fan (if you have one).
jrock [OP]
  • Turtle Points: 77
  • Male Posts: 3,395
  • Oodelally
Re: Cooling Issues
« Reply #10 on: Jun 17, 2009, 10:33:04 PM »
I was thinking clutch fan but why would it be stay cool driving around town and not on the highway.
potter85
  • Male Posts: 257
  • Member since May '09
  • complete disregard for sheet metal.....
Re: Cooling Issues
« Reply #11 on: Jun 17, 2009, 10:37:24 PM »
water pump? mine did weird things when the water pump went out....
3rz in the making
looking for 38s
2 tundra 4.7l v8 soon to be sas'ed
jrock [OP]
  • Turtle Points: 77
  • Male Posts: 3,395
  • Oodelally
Re: Cooling Issues
« Reply #12 on: Jun 17, 2009, 10:41:36 PM »
Just replaced ~5000mi ago. Cooling issue started ~500mi ago. Actually started after I found my #3 spark plug wire (Accel) fried and then replaced it with a cheap Auto Lite but recently switched them all to the Auto Lite.
DeadlyPeace
  • Male Posts: 593
    • ToyotaOffRoad
Re: Cooling Issues
« Reply #13 on: Jun 17, 2009, 11:08:21 PM »
When running higher RPM's the fan can't keep up with the engine and will spin slower then it should. Usually you can check it by spinning the fan and seeing how easy it turns.
BTW, best to stick with NGK plugs.
fordh8r
  • Turtle Points: 850
  • Male Posts: 2,588
  • Member since Jan '07
  • when my toyota grows up it'll be just like my chevy!
Re: Cooling Issues
« Reply #14 on: Jun 18, 2009, 12:15:07 AM »
Generally, it should run cooler at higher speeds since you would have the air moving through the radiator to cool the engine. But at lower speeds the fan is needed in place of the rushing air at speed to cool the radiator.
If it runs cooler at lower speeds (less heat generated at lower RPMs and lighter loads) I might guess the fan clutch is working. Since it runs hot at higher speeds as you described, (when more heat is generated by the engine, I.E. more engine load and higher RPM) if the radiator is not efficient enough it may want to run hotter.
Is the radiator full of mud or a lot of crud like bugs, birds, small animals or children? Even heavy amounts of dirt build up will cause problems like you described. If so, you can blow out the crud with compressed air. You'll be amazed how much crap will come out of a radiator. Especially if you've spent any amount of time on dirt roads.  :o   :twocents:
Sounds like it's probably something simple.  :crossed:
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: Cooling Issues
« Reply #15 on: Jun 18, 2009, 08:34:08 PM »
very likely the engine is running lean
  • Turtle Points: 1128
  • Male Posts: 9,757
  • Member since Oct '04
Re: Cooling Issues
« Reply #16 on: Jun 18, 2009, 08:59:20 PM »
No offense whatsoever to anybody else, but DING DING DING!  My 2wd has a bit of crusty buildup in the radiator and runs cooler at lower speeds but runs hotter on the freeway, and even hotter towing.  My radiator is a little plugged and isn't flowing what it should, period.  If I had it rodded out I can absolute guarentee my truck would run cooler.
jrock [OP]
  • Turtle Points: 77
  • Male Posts: 3,395
  • Oodelally
Re: Cooling Issues
« Reply #17 on: Jun 18, 2009, 10:34:32 PM »
Hmmmm. Well I didn't get to do anything today cuz of my running around but tomorrow, tomorrow I will get to it.
hilux-1983
  • Turtle Points: 3
  • Male Posts: 1,271
  • Member since Apr '09
Re: Cooling Issues
« Reply #18 on: Jun 18, 2009, 10:41:44 PM »
 :dunno:
jrock [OP]
  • Turtle Points: 77
  • Male Posts: 3,395
  • Oodelally
Re: Cooling Issues
« Reply #19 on: Jun 21, 2009, 04:41:10 PM »
Took out the thermostat and boiled it with a new thermostat. The old opened but only a 1/4in while the new opened 1/2in. I think I got the problem. Thanks for the help everyone. I won't know if the problem's fixed until I go for a nice long drive. I'll get back to you with the results.
 :biggthumpup:
fordh8r
  • Male Posts: 2,588
Re: Cooling Issues
« Reply #20 on: Jun 21, 2009, 05:10:17 PM »
That would be simple enough.  :yupyup:
jrock [OP]
  • Turtle Points: 77
  • Male Posts: 3,395
  • Oodelally
Re: Cooling Issues
« Reply #21 on: Jun 21, 2009, 05:37:49 PM »
Your telling me. ;)
jrock [OP]
  • Turtle Points: 77
  • Male Posts: 3,395
  • Oodelally
Re: Cooling Issues
« Reply #22 on: Jun 24, 2009, 11:15:16 PM »
You jinx  :( The problem is still there. I really need to look in the radiator.  :thumbdown:
fordh8r
  • Male Posts: 2,588
Re: Cooling Issues
« Reply #23 on: Jun 24, 2009, 11:29:42 PM »
:behindwall:  Although, I never mentioned anything about the thermostat.  :disturbed:
Just remember not to just look inside the radiator but the outside too. Anything that plugs the radiator core exterior will cause you problems. If you can, used compressed air to blow through the radiator from the Back (fan side) and watch to see what comes out. It might surprise you.  :yupyup:
jrock [OP]
  • Turtle Points: 77
  • Male Posts: 3,395
  • Oodelally
Re: Cooling Issues
« Reply #24 on: Jun 24, 2009, 11:46:26 PM »
Haha :biggthumpup:. I shall do my best to thoroughly clean my radiator and get back with more results.
fordh8r
  • Male Posts: 2,588
Re: Cooling Issues
« Reply #25 on: Jun 24, 2009, 11:50:55 PM »
 :whip:
jrock [OP]
  • Turtle Points: 77
  • Male Posts: 3,395
  • Oodelally
Re: Cooling Issues
« Reply #26 on: Jun 28, 2009, 09:49:08 PM »
New results. After taking a good strong hose to the front of my radiator I was able flush out quite a bit of dirt  :rofl2: . Thanks again for the tips  :thumbs: . I'm pretty sure the issues been fixed, my truck takes for ever to heat up again  :laugh::beerchug:
fordh8r
  • Male Posts: 2,588
Re: Cooling Issues
« Reply #27 on: Jun 28, 2009, 09:56:03 PM »
Cool!  :biggthumpup: (pun intended)  :disturbed:
  • Male Posts: 9,757
Re: Cooling Issues
« Reply #28 on: Jun 28, 2009, 10:27:10 PM »
Good deal man  :wink2:
cooling ?
Last post Oct 17, 2006, 01:11:42 AM
by 2utadud
Last post Jan 22, 2008, 12:24:50 AM
by Tallchevy
Last post Jul 08, 2008, 02:18:52 PM
by GJToyotabug
Last post Feb 15, 2010, 07:58:33 AM
by 2manytoys
Last post Aug 17, 2010, 07:36:15 PM
by jimbo74
