Author Topic: Grinding / Whining noise when clutch pushed in only in 5th gear...  (Read 1499 times)
mmessier2
  • Turtle Points: -2
  • Member since Mar '06
85 4runner, 5spd
Im trying to diagnose a small issue with my 4runner.  When I am exiting the freeway and I put the gear in neutral I hear a whining or slight grinding sound coming from the transmission area.  It isnt loud, but it is noticeable.  It doesn't make this noise when it is in any other gear, only at high speed in neutral. When I put it in gear the noise goes away. Any ideas on what it is?
Mark
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
:headscratch:  um  why do you put in the clutch when your exiting the freeway??  when exiting you should downshift to 4th and release the clutch.  if your pressing the clutch  and/or  shifting into neutral at freeway speed then  your  killing your  input and or main bearings since in neutral the  lower gears arent slinging oil up onto the other gears
i had a girlfriend years ago  and she always complained that her clutch never lasted more than 6 months,   one day i was injured at work and she came to drive me home.   when exiting the freeway  she pushed the clutch to the floor, i watched as she  went all the way down the ramp to the redlight with the clutch on the floor.  i asked her if she always did that,  she said "well yea, your supposed to"   i proceeded to inform her she was NOT  and  thats why her clutch never lasted more than 6 months
ROCKO
  • Turtle Points: -49
  • Male Posts: 743
  • Member since Sep '07
  • NOR-CAL WHEELIN
my 4-runner does the same thing. the reason mine does that is because i believe it is the drive line where they come together the splines are worn out (slip yoak) i think. i grease it up and it goes away and comes back a few weeks later.....check the drive line for play :twocents: good luck
JUST ANOTHER ROCK CRAWLER....
with a lot of good stuff
F@$K CANCER
Last post Sep 26, 2005, 09:01:03 PM
by ksmith
Last post Nov 03, 2005, 03:48:30 PM
by dentedfender
Last post Jan 17, 2010, 06:03:41 PM
by 85_4RNR
Last post Jun 12, 2013, 06:20:42 PM
by se3388
Last post May 11, 2019, 05:37:12 AM
by Gnarly4X
