If I remember correctly LCE headers are actually made by Thorley.
Well it depends where you are. Thorley is pretty much the only decent option if you are in "Kalifornia" and have to also pass smog/have it also be CA smog certified. Thankfully the little 22 series engines don't have enough power to be noticeably choked off by the CA smog certified headers. If it was a V6 or V8, yeah, if you're not in CA, don't get a CA approved model obviously because it'll hurt your power.(the Thorley for the 22RE seems to be about right where the engine hits its sweet spot between power and torque - and is noticeably better than stock)
Started by jesusfreak_ph Engine
Started by 84runner Parts Wanted
Started by pulpfunction Parts Wanted
Started by yota83 Parts Wanted
Started by KDXSR5 « 1 2 ... 6 7 » Toyota Pickup/4Runner Tech 1979-95
