how do the shoes look compared to the pads? if the pedal doesn't drop when you crack the bleeders then most likely you have a blocked or collapsed line. also remove the bleeders completely from the wheel cylinders and clean the bleeders out with a small drill bit. i have seen them rust shut when people loose the rubber boots that go over them.
LSPV sorry kinda toyota illiterate
Started by trollbum General 4WD Discussion
Started by surfindave Engine
Started by yotacrawler4 Engine
Started by gmrwizard Toyota Pickup/4Runner Tech 1979-95
Started by toyzuki Project Research and Build-Ups
