Author Topic: Flat towing  (Read 6678 times)
jafish
  • Male Posts: 37
  • Member since Aug '06
Flat towing
« on: Aug 18, 2006, 04:41:26 PM »
I have a 85 Toyota that you can read about here ( http://board.marlincrawler.com/index.php?topic=26565.new#new ). I was wondering if it'd be ok to flat tow it from Kansas to Ohio (750 miles) as is. I know I need to remove the rear drive shaft and ensure that the hubs are in 2 wd. However, with 5.29's and Detroits, will it be ok? i.e. bad for the gears, lockers, steering, etc... I once saw a Toyota truck being flat towed down the road by a bus, and the driver didn't know that the Toy's steering was locked in the turned position, so the front tires were being drug down the road sideways. Luckily he had just turned out of a gas station and we got his attention quickly. Anyhow, I just don't want something like that to happen to me.
Josh
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
Re: Flat towing
« Reply #1 on: Aug 18, 2006, 04:45:45 PM »
i dont know exactly how you keep the steering wheel from locking, but other than that, it should be fine, the fluid in the diffs will be ok and without hte driveshaft nothing else will turn that needs to have oil lubrication
my steering wheel doesnt lock anymore, it used to, but it jsut doenst anymore?
might jsut leave it in the key on position...
youre probably going to need trailer lights, the magnetic kind or some sort, as im sure the cops will say somethign about it...
BLACKDOG
  • 3.0 Killer
  • Turtle Points: 718
  • Male Posts: 7,644
  • Member since Aug '04
  • I used to fit
Re: Flat towing
« Reply #2 on: Aug 18, 2006, 04:49:01 PM »
you'll be fine, just leave the key on :thumbs:
              -Ronald Reagan
jafish [OP]
  • Male Posts: 37
Re: Flat towing
« Reply #3 on: Aug 18, 2006, 05:02:52 PM »
Yeah, I was thinking of unhooking the battery and leaving the key on.
Josh
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: Flat towing
« Reply #4 on: Aug 18, 2006, 07:55:44 PM »
yea, im sure what the bus guy did  was turned the key off when he got something out of the truck at the station,
just make sure the key is on  and the rear shaft is out and tow like a mad man
dirtoyboy  is in stlouis  maybe he will be back befor you do this, he just towed a guy from colorado to missouri  with his toy
jafish [OP]
  • Male Posts: 37
Re: Flat towing
« Reply #5 on: Aug 18, 2006, 08:02:07 PM »
Does he hire out? I doubt I could afford it even if he did.
Josh
brainlessfool
  • Turtle Points: 2730
  • Male Posts: 4,207
  • Member since Jun '02
    • Buy me a cigar
Re: Flat towing
« Reply #6 on: Aug 18, 2006, 08:02:31 PM »
NO NO NO! never tow flat! NEVER!!
put air in the tires frist!  :think:
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Member since Jul '04
  • Lego Enforcement
    • Spinnin4s 4x4 Club
Re: Flat towing
« Reply #7 on: Aug 19, 2006, 09:50:49 AM »
:rofl:
Pull the rear ds, what I did was to mark the the ds on both ends of the splines and only remove the rear 4 bolts and slide the ds out and leave the rest just hang, but you can only do this if you have the ds in the standard way where the yoke is to the tcase. You can also just tie it up, just make sure it is secure, sucks to get to your destination and find half of your ds missing. You don't really need to disconnect the battery just turn the key to the on position then turn it back to the acc position the steering wheel will not lock in that position. Of course the hubs should be unlocked and most importantly if you leave the front piece of the ds in you cannot drive it off the front axle, it will bang around. It will not hurt your locker either.
notajeep
  • Turtle Points: -108
  • Male Posts: 703
  • Member since Oct '04
  • Crawler #3289
Re: Flat towing
« Reply #8 on: Aug 19, 2006, 10:17:15 AM »
All good points of advise above. One thing I learned when I was flat towing, was that is alot of weight to pull with no brakes (3500lbs).  I towed to moab once with a 01 4runner and the truck pushed the 4 runner all over the road. When on a tow bar, you now have two points of articulation, one at the ball and the other at the front tires. So when the tow vehicle turns, there is a delay before the towed vehicle will start the turn. Normally this is not really an issue EXCEPT, if you are braking and turning at the same time. The towed vehicle will still be going straight while the tow vehicle is turning and depending on the weight of the tow vehicle, it can push your rearend around pretty easy. Flat towing with 4 runner = scary. Flat towing with F350 stroker = fun.
jafish [OP]
  • Male Posts: 37
Re: Flat towing
« Reply #9 on: Aug 20, 2006, 07:14:54 AM »
I may actually be screwed now, my friend who was going to tow it for me with his 03 Super Duty diesel is trading it off for a car, and my backup just totaled his Silverado on the highway near Kansas City.
Josh
old school toy
  • Male Posts: 148
  • Member since Apr '06
Re: Flat towing
« Reply #10 on: Aug 20, 2006, 08:13:59 AM »
Why do you have to remove driveshaft???  Can't you put the transfer case in neutral and tow that way???
1988 4runner
Re: Flat towing
« Reply #11 on: Aug 20, 2006, 08:44:14 AM »
because it then spins the internals of the tcase, if you are goiing 10-20 miles NBD  but going 700  its far better to remove the shaft,  easy cheap insurance
Jafish,  you could tow it useing a dolly,  ive done this with my 79  towing a 86 4x4  didnt go but 40 miles but it can be done  and is easier than flat towing
jafish [OP]
  • Male Posts: 37
Re: Flat towing
« Reply #12 on: Aug 20, 2006, 08:02:22 PM »
I could, but I'm still at the crossroads of having no tow vehicle.
Josh
DTB
  • Shoutbox Moderator
  • Turtle Points: 2
  • Male Posts: 7,110
  • Member since Nov '05
Re: Flat towing
« Reply #13 on: Aug 20, 2006, 08:12:35 PM »
i towed an '83 (loaded with gear) from CO to MO (1000+ miles) on my 22re (on a uhaul dolly) so it can be done. and yes, this is my dd too. I wouldn't recommend towing that far unless it's absolutely necessary (we were stuck out there) She made it but I think she's still angry at me :slap: dont tell oldskool i posted this pic here either. i think he's still a little sensitive
Quote
unclejpl4x4
  • Turtle Points: 348
  • Male Posts: 3,522
  • Member since Apr '05
  • Broke & rusted
    • myspace
Re: Flat towing
« Reply #14 on: Aug 20, 2006, 08:23:15 PM »
thats crazzy
DTB
  • Turtle Points: 2
  • Male Posts: 7,110
Re: Flat towing
« Reply #15 on: Aug 20, 2006, 08:27:04 PM »
yup  :screwy:
Quote
  • Momentum Man
  • Lego Enforcement
Re: Flat towing
« Reply #16 on: Aug 21, 2006, 09:22:36 AM »
I think it depends on the vehicle, I could tow my Willys and my Ranger with my 80 Toy and I could tow my 80 Toy and my Willys with my Ranger but it was very squirlly while my 80 Toy didn't budge.
Cheesemaker
  • Turtle Points: 1363
  • Male Posts: 4,525
  • Member since Sep '04
Re: Flat towing
« Reply #17 on: Aug 21, 2006, 11:17:25 AM »
If ya don't have access to a tow rig, just go to u-haul, get a truck and throw down some ramps load it up and drive away!  This is how I will probably do it when I get mine!  Everybody I know is getting rid of their big pickups!  I know a couple friends had their Harley's break down along the way back from Sturgis did this!
Another trick is AAA!  I've know people to buy a rig, and have no way to get it home, but they have AAA, so they call the towing co.  :thumbs:
I'd always try to tow with a trailer or a dolly, never flat tow!
jafish [OP]
  • Male Posts: 37
Re: Flat towing
« Reply #18 on: Aug 21, 2006, 11:46:31 AM »
I thought of this, I've actually seen pics of it done on the internet, but, how would you tie it down? I'd hate to have it bouncin' around in there.
Josh
Re: Flat towing
« Reply #19 on: Aug 21, 2006, 12:01:20 PM »
the only way in a van like that is pull it all the way till it bumps the front then somehow wedge the rear of all 4 tires,  but i really dont recommend this as you will be liable for damage to the van
Cheesemaker
  • Male Posts: 4,525
Re: Flat towing
« Reply #20 on: Aug 21, 2006, 12:11:54 PM »
Rent the the straps that lock into the rails that goes down the sides of the truck!  And strap it down!  And let the air out of the tires that will act like wheel blocks.   If ya got the e-brake on, tires empty of air, and straped to the rails inside the truck, you should have no problems!  How fast do ya think ya can drive a u-haul truck?
jafish [OP]
  • Male Posts: 37
Re: Flat towing
« Reply #21 on: Aug 22, 2006, 06:01:40 AM »
Looked into it, it's still outside my price range, it'd be around 600-650. So, I'll keep tryin' to figure it out.
Josh
Hottrod81
  • Turtle Points: -2
  • Male Posts: 1,392
  • Member since Feb '05
  • Full Trucker Effect
Re: Flat towing
« Reply #22 on: Aug 22, 2006, 07:34:06 AM »
The only bad things about flat towing is that you break something and need a trailer to get it home.
  • Momentum Man
  • Lego Enforcement
Re: Flat towing
« Reply #23 on: Aug 22, 2006, 09:27:08 AM »
I've always found the best cure for this problem is to not break your rig. :gap:
Last post Jul 15, 2004, 09:02:55 AM
by 84runner
Last post Apr 11, 2005, 04:37:59 PM
by notajeep
Last post Oct 22, 2006, 03:41:38 PM
by notajeep
Last post Feb 03, 2007, 08:34:47 PM
by kneedownnate
Last post May 12, 2012, 05:42:55 PM
by steveco.
