ill try anything at this point, but it sounds normal when cranking over. and i found out im not gettin any power to the fuel pump
test the fuel pump, and check all your fuses again. since you say that, I'm betting you blew one at some point. It had to have happened when you swapped batteries, or pulled the starter, because you said you drove it to the shop, after push starting it.
