Author Topic: Transmision problem  (Read 2103 times)
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Member since Jul '04
  • Lego Enforcement
    • Spinnin4s 4x4 Club
Re: Transmision problem
« on: Nov 14, 2012, 03:03:23 AM »
From your second post it sounds like you have removed the front ds so if you have it in neutral and the rear either disconnected or the rear tires off the ground you should be able to turn the rear ds with your hands. Sounds like something is wrong inside, don't know what it may be but it should be looked into. Could even lock up which if you were driving it may not end well for you. In neutral the fact that it is attached to a motor is not a factor and if there is still a tcase that would not be a factor either.
Last post Apr 12, 2005, 07:20:47 PM
by backseatwheeler
Last post Sep 08, 2005, 06:58:06 PM
by yotaboy79
Last post May 15, 2006, 12:25:38 PM
by BoG-ToY
Last post Feb 17, 2012, 08:29:04 AM
by junya92toy
Last post Dec 24, 2015, 10:35:04 AM
by tryn2Crawl
