Author Topic: help with 4runner back window problem  (Read 1454 times)
camhays556
  • Turtle Points: 498
  • Member since Nov '12
« on: May 12, 2015, 09:08:28 AM »
Hey guys, I have an 87 first gen 4runner and the rear window will not roll up. I have been reading for the past three days on forums and have not found the issue.
I soldered in all new relays from radio shack.
 jumped the switch in the center console
 jumped the switch in the driver side where the shell bolts to it.
I can not find any cut wires and have tested the window motor and it works because I am able to jump it with 12v and some wires.
Any ideas? Thank you
helipilot77
  • Turtle Points: 1018
  • Male Posts: 1,728
  • Member since Jul '12
  • Seattle, WA
    • My build thread
Re: help with 4runner back window problem
« Reply #1 on: May 12, 2015, 10:11:52 AM »
There is also a switch inside the gate that opens the circuit when the gate isn't fully latched. Check that one too.  I am going to assume you made sure that you had good power and ground before doing all that other stuff. I had a bad switch at the key on mine, but I was still able to operate it from the forward switch.
LittleSteve
  • Turtle Points: 170
  • Male Posts: 943
  • Member since Jan '14
  • What is this Toyota you speak of?
    • Buy me some coffee
« Reply #2 on: May 12, 2015, 10:19:30 AM »
There is also a switch inside the gate that opens the circuit when the gate isn't fully latched. Check that one too. I had a bad switch at the key on mine, but I was still able to operate it from the forward switch.
This is the one problem that lets the runners down, ive got to rectify the relay issue, i had three control boxes lying round, all of them are shot.
Ive found panasonic relays to replace the factory ones so we'll see what happens.
Refusing to fit in or comply.
Easy is not worth anything.
camhays556 [OP]
« Reply #3 on: May 12, 2015, 02:33:32 PM »
I didn't know about that switch, ill check it out. thanks
camhays556 [OP]
« Reply #4 on: May 12, 2015, 04:51:23 PM »
I dont know much about electrical so I am learning on the go.. I tested for power at the switches in the center console, and none of them have power going to them.. When I tested the wires coming out of the driver side fuse panel, all have power but 2 of the prongs in the plastic connector. Not sure what this means
Last post Jun 17, 2006, 11:29:21 PM
by boggerunner
Last post Oct 20, 2009, 08:20:55 AM
by caliyota420
Last post May 08, 2012, 08:02:17 PM
by jl93221
Last post Dec 03, 2014, 08:16:57 PM
by Kentucky Jelly
Last post Feb 03, 2019, 07:52:00 PM
by Jimkola
