I'm sure someone else will chime in. The easiest way would be to use a weber but it looks like you're doing OK to me. I would keep using the stock distributor, no reason to change that. EGR and air pump block offs, plug your unused ports and you should be good to go. There are a bunch of good write ups on de-smogging the 22r carb. Here is one: http://www.yotatech.com/f114/22r-desmog-tutorial-264405/ 20r carb is pretty similar, maybe even a few less things to mess with.
I could never get that GM igniter mod to work on my 20r.
Run a weber and you'll have the 2 vac lines to the distributor and 1 to the break booster and that's it. I have some nice pics of some desmogged 20Rs if you want some. I also have a nice diagram for the GM igniter if anyone needs one they work sweet.
Started by John rogers New Announcements and Info
Started by GRM Engine
Started by scheid6996 « 1 2 3 4 5 » General 4WD Discussion
Started by hbar314 Parts Wanted
Started by h0nke General 4WD Discussion
