My Headlights Suck.......looking for replacement ideas
Started by BPINAZ, December 16, 2014, 06:57:35 PM
BPINAZ
I'm considering replacing my headlights on my 85 with some decent round off road lights. I've seen pics of rigs that have had this done, just looking for some ideas. Post up some pics for inspiration if you have any. Thanks.
If you're gonna be dumb, you better be tough. I've got the scars to prove it
SqWADoosh
I just went with the Vision X housings and super white bulbs that Marlin sells and I tell you what they are a hell of a light for what they cost. Not to mention they drop right in without any need to change out your harness or anything!
BPINAZ
Thanks, I'll check into those. I'm looking at some other lights that Marlin sells too. Btw, nice rig.
John Doe
Years ago I purchased the Roundeyes replacement head lights, An amazing upgrade!
BPINAZ
Is there a kit for the round eyes that's available?  That's kind of what I'm leaning towards. Thanks.
Nation
I also bought the vision X set up. I am not impressed in any way. The low beams are too dim and the hi-beam isn't very Hi lol. I like the fact I can change out my bulbs now.... but over all I would go a different route if you're looking for performance. IMHOP
SqWADoosh
Quote from: Nation on December 17, 2014, 07:51:27 AM
Interesting that we differ so much in our opinion of them. I guess I don't need low beams that are led light bar bright as my truck is my daily and I'm not trying to be that guy with the lifted truck and the blinding bright lights in everyone's rear mirror. They are a 100% improvement over my sylvanias that were in the truck before so maybe that it is that they were so bad that these are tainting me into thinking these are so good  :yupyup:
Nation
My trucks my daily driver and I wish I had something better. I have newer wiring and using the 3rz fuse box to operate the headlights.  I have adjusted them multiple times with alignment tools and visually to try and make the beam work better for me. No luck. In my situation,  compared to the lights in my truck right now, the prius behind me is the Dbag with the brights..
John Doe
Well I just checked the RoundEyes site and it looks like they no longer sell there rectangular toyota replacement headlights. that sucks I really like mine. Just double checked  :turtle:'s lights and I am betting they are the same lights.
BPINAZ
Thanks guys for the advice.  I found a few builds where guys have mounted the "KC" style lights in place of their headlights.  If I can't find a roundeye solution,  I might go this route.
SqWADoosh
Quote from: BPINAZ on December 17, 2014, 11:30:25 AM
Yeah pretty sure that would be illegal for use on the road. Don't know if your truck is a dedicated trail rig or not but something to consider.
mudmaster
I have some square Roundeyes that I no longer need. The 130/90 bulbs are installed in the Roundeye headlights already. I can't remember what the ones in the box are.
Time to go wheelin!
4.3 headache
Quote from: BPINAZ on December 16, 2014, 06:57:35 PM
Before scrapping your lights alltogether, take a look at 4crawler's website:
http://4crawler.com/4x4/CheapTricks/Headlights.shtml#WiringHarness
There's some good info in there. The guy is an engineer,so it's pretty detailed. Keep in mind that any high wattage replacement bulb or off road light you tie into the factory harness is going to put quite the strain on the electrical system. The problem is voltage drop through the factory wiring, not so much the lack of bulb wattage.
You can upgrade your lights only, but it'd be like running a 350 chevy in front of a stock W56 tranny.....
all i want is a little more than i'll ever get!!
helipilot77
HELLA still makes a good H4 conversion kit. It also bolts right in and is only about $60. I think the difference between the two results that SqWADoosh and Nation are experiencing has to do with the actual H4 lamp being used. The reflector alone isn't going to improve the lights other than having a more precise beam and having the ability to use a brighter lamp.
I am using the Trucklite LED's. They are expensive though. The benefit is that they are super bright with a very high light temperature and a brightness right on the edge of the legal limit. they also require no wiring harness upgrades, draw very little amperage and will outlast the vehicle. Well maybe not, it is after all a TOYOTA.
LittleSteve
Got LED replacements coming from China, 6600 lumens bright white, cheap, straight swap for h4. Bright as the sun when fitted into focused reflectors.......
Refusing to fit in or comply.
Easy is not worth anything.
helipilot77
You should post some before/after pics once you get them.
