Hello, this is my Pile: 1986 4Runner SR5
Started by BigBluePile, November 21, 2014, 04:02:20 AM
BigBluePile
Quote from: THK Matt on July 24, 2017, 09:34:15 AM
do did you just move the LP front diff to the rear? making room for your HP Excuse :boobs:
Yup yup!  [emoji13]  I have had the HP diff for a while now though.  So, yes, perfect excuse.
Sent from my 0PJA2 using Tapatalk
'86 4Runner SR5 TRD 5VZ-FE
...slightly modified from OEM...
seal13il
BigBluePile
BigBluePile
May have found the problem....
You can dress the gears to fix that.............
:cheese:
BigBluePile
Quote from: emsvitil on August 01, 2017, 06:45:50 PM
:cheese:
Heck ya I did!  Then I sold it to a guy on a FB forum.
BigBluePile
Well, that was fun.  Local car show, entered the 4x4 category.
BigBluePile
Took my junk up for some snow fun!!!
SqWADoosh
BigBluePile
gnob
hold this. . .
BigBluePile
Quote from: gnob on November 06, 2017, 06:58:11 AM
Nice rig.  Wish i had the SC on mine ;)
It gets me up to 95....
snowcrash
nice truck, just wish ours ran and drove good like many of yours.  think if i had a new engine and transmission, i might be happy!
BigBluePile
Quote from: snowcrash on November 27, 2017, 05:46:22 PM
Thanks.  It's a very long winded project that's been in various stages lol
Sent from my 2PZC5 using Tapatalk
BigBluePile
Well, that's interesting.
:)bestgen4runner
Quote from: BigBluePile on February 04, 2018, 08:31:29 AM
I demand more info!
I am 1/5th of Perfect Fit
BigBluePile
Quote from: :)bestgen4runner on February 04, 2018, 12:10:28 PM
I demand more info!
Lol, good news is my welds held.  Bad news the frame did not.  Longer lever arm from the shock mount.  Plus, not welding along the top probably did help either.
:)bestgen4runner
Weld/ damage diagnosis required.
Come on boys, let's hear what We all think caused this.
I suspect to much heat during the welding process?
Weakening the the frame material.
Can We see a good picture of the tear out.
Quote from: :)bestgen4runner on February 04, 2018, 05:47:12 PM
Why do you suspect that?  There are so many factors. Fitup, weak frame metal from years of deterioration, welding issues, etc...
BigBluePile
Quote from: blackdiamond on February 04, 2018, 06:13:18 PM
Probably all of the above.  Once the truck dries out and I get time when it's not raining all day....I'll take a gander.  If my shock bracket went all the way across or was gusseted at the top may have worked out better.
Never thought about weakening the metal but it's possible?   I am using a flux core welder.  Plus the bracket is quite thick verses the frame material.
:)bestgen4runner
It's just something I consider on every weld I perform.
It was meant more to start the diagnostic process.
I currently consider Myself a welding student. Under the tutalige of trial and error.
So for Me every failure is an opportunity to learn and get better.
I appreciate the information about the process used (flux core) as it definitely helps in the diagnosis.
From My limited experience I have learned that flux core welding tends to run very hot.
BigBluePile
Quote from: :)bestgen4runner on February 04, 2018, 06:53:59 PM
I am by no means an expert of anything.  I imagine at the time I concentrated on the thick metal and then drug the puddle to the thinner material.  Knowing how much hotter flux core can be.
I believe the bigger shocks, Rancho 9000 something or others, did a fantastic job damping oscillations.
:)bestgen4runner
That would be My plan also. Slightly longer to dwell on the thicker material.
I recently have been playing with gun angles.
I have found it can make a huge difference.
BigBluePile
Quote from: :)bestgen4runner on February 04, 2018, 09:19:14 PM
Interesting.  Guess I'll keep that in mind next time.
I spent the afternoon welding in a roll cage in my son's rig.  Hopefully it'll hold together better than my shock mount....
BigBluePile
Better than my shock mount....tough crowd in here...
So, in celebration I bought more aux lights.  Technically, I accidently won an auction....
BigBluePile
'Bout to swap this old 4Runner body onto a newer more modern day chassis!
BigBluePile
Quote from: THK Matt on August 16, 2018, 11:24:02 AM
badass dude! what platform is it?
It's just an old Traxxas 1/10 Slash chassis my son has.  Gonna have to make custom mounts but it'll fit.
Quote from: BigBluePile on August 16, 2018, 06:21:16 PM
Traxxas is where its at.
