Author Topic: Excess Hub Heat - Post Axle Rebuild  (Read 960 times)
jssgbsn
  • Turtle Points: 440
  • Member since Sep '13
« on: Aug 23, 2014, 06:16:36 PM »
Finished the axle rebuild  :D
The only thing that I am noticing that is off is a lot of excess hub heat (not warm, hot).
The best thing I can come up with is my brakes are sticking/engaged slightly while driving.
Tomorrow I'm gonna jack the truck back up and spin the tires.  I'm guessing if they are rubbing it'll be obvious.  If that's what is happening what should I do?  Open the MC and pump the brakes, then rebleed the system?
TIA (Thanks in Advance) for any input.
If I don't ask the stupid question, who will?
85 Runner, 22RE, AEM 'warm intake', TRD Cam, LC Headers, Dual Case, 5.29's, ARB Front Locker, Detroit Rear Locker, 35's, V6 Brakes, ARP Studs, Marlin Arms/Caps/Hy-Steer, Winch, Armor, Can-Back Top....and...
...more Gremlins than Gizmo the Mogwai was responsible for.
1985CRAWLER
  • Turtle Points: 267
  • Male Posts: 1,163
  • Member since Feb '13
  • Backyard Built
Re: Excess Hub Heat - Post Axle Rebuild
« Reply #1 on: Aug 24, 2014, 05:31:22 PM »
if the hub is hot its usually the wheel bearings, too tight is always the case ive seen but it could be the brakes dragging too, turn the truck on and have someone depress the brakes and see if the calipers are working correctly. goodluck!
Last post May 30, 2005, 02:17:20 PM
by 86yota
Last post Jun 11, 2007, 10:53:12 PM
by 808-Yota
Last post Jun 08, 2009, 01:53:57 PM
by toytank
Last post Jun 08, 2013, 02:04:13 PM
by tgmaul88
Last post Nov 21, 2013, 11:07:42 PM
by builttoabuse
