Need help with axle rebuild.
Started by Crawler677, June 08, 2009, 10:45:08 AM
Crawler677
Ok so you guys may or may not have seen my post about rebuild a front axle. Today i started tearing into it. pulled off the cap on the hub pulled the snap ring, then got the cone washers out and proceeded to remove the hub body and spindle, this is where i get stuck. I have never done this before but i have watched it be done and read alot about it, and everythign i know about it tells me that the birf and inner axle slide out together. well, i pull on the birf and it comes off the inner shaft  :smack:, leaving the inner shaft stuck in the housing. I did not put this axle together but i know now that the guy who did did not do something right  :thumbdown:. I cant seem to get this axleshaft out now, and of course since its a yota setup theres no inspection cover to get in there and get it from the inside.  :down:
Please help me guys i need ideas.  :crossed: all i have tried is pulling on it with some channel locks so far.
toytank
sometimes it does that i dont know that it was installed wrong, however have you tried rocking your pinoin gear while someone pulles on the shaft it sounds like its in a bind
old and sqeaky but she goes
Crawler677
#2
Quote from: toytank on June 08, 2009, 10:50:03 AM
I havent tried that, i'll try it and get back to ya.
Edit: no dice.
Does anyone here know if ARB's are open throught middle? im guessing no but i sure hope they are.
toytank
no they are not. do you have another axle you can steel the snap ring off of and slide the birfield back on and try that. or maybe a slide hammer that you can hook on there and give it a nudge
Crawler677
I dont have another axle i can grab a snap ring off of. however i was thinking about using a slide hammer, my only thing is, how would you attach it to the axle? One thought i had was tack welding a nut to the end of it. but i just dont know. its as though he put a snap ring on the shaft before he slid it in or something. leaving it stuck in the Carrier.
Crawler677
Alright im good i got it, Big vice grips with a short peice of chain wlded to em and a slide hammer, they popped right out. Thanks for your help toytank.
toytank
