I need to buy 1981 toyota pickup FSM
Started by gordon oehrlein, August 22, 2014, 05:37:28 PM
gordon oehrlein
I have a Toyota pickup  1981.  I can't keep the  engine running, rebuilt the carb, had the generator, distributor checked out and they're good inspected the hoses, wiring.  the fuel pump is good.  Any suggestions?
GONZO97
what exactly is going on with it? will it turn over at all? start running then stop?
1997 4Runner Limited 3" lift on 31 M/Ts-Traded
http://board.marlincrawler.com/index.php?topic=61054.msg749103#msg749103
1995 Xtended Cab SAS on 35's Dual Cases-Sold
1991 4Runner SAS on 33s RUF 63's in the back Bilsteins all the way around, 5.29s front and rear Detroit locked Front and Rear http://board.marlincrawler.com/index.php?topic=65180.0
1988 4Runner 3.0 V6--SOLD
http://board.marlincrawler.com/index.php?topic=97592.msg1086573#msg1086573
1996 Toyota 4Runner 3.4 V6 3" OME Lift Springs 33" Duratracs
The Build:
Coming Soon
Go to tech and ask this question it may help you to get more answers.
beech23driver2010
I have a similar problem with my 81 22r, but it is intermittent.  It always starts and usually idles fine on the first start of the day.  After that it is a crapshoot as to whether it will idle or not.  I can keep it running with my foot on the gas, but it runs rough.  After I start off it accelerates fine and goes along at highway speeds for hours at a time with no trouble.  When I pull off and stop it may idle or not.  I checked the anti-dieseling valve and I hear a click when it is energized.  I replaced the fuel pump, all of the vacuum hoses, drained some gas from the tank and checked for water, sprayed carb cleaner in and around carb, checked carb sight glass for proper level, checked choke for cold start operation.  What am I missing?  Thanks for any help.
