Does it do it with the valve cover off?I'm thinking the rocker arms are hitting it.......
I had a cracked rocker arm that did the same thing
Wrist pin?
have you ever heard a 22re rod knock before this?at around 15 sec. it sounds just like my old 22re which had the 1st and 2nd rod bearings toasted, it would idle fine but then once the throttle was applied and between that and 2500 rpms under load it would make that sound,kinda sounded like a wood pecker tapping on the side of the motor.........
Started by DontStall Rockcrwl Engine
Started by snowshoebrue Parts For Sale
Started by JANDO11 « 1 2 3 » Project Research and Build-Ups
Started by MC387 Parts Wanted
Started by Lewis Hein Transmission/Clutch
