Strage Clacking noise....
Started by DontStall Rockcrwl, September 08, 2004, 11:08:08 AM
DontStall Rockcrwl
my truck did the same thing before and i was told it was a bent output shaft... when i give it gas, it makes a large thumping noise. when i let off the gas, it stops. it doesnt sound like a rod knocking or anything... sounds like its coming from the rear. the steel brake line that goes from drum to drum is pinched at one side. could this be the problem? i was thinking it could be the brakes trying to engage. when i try to go downhill in neutral the truck doesnt move. so could the brake line possibly be causing this?
You have all gotta be jealous how close i live to the 'Con
so your truck will not roll naturally on its own with a slight down slope? Thats not good man. Your brakes are dragging, dumbs getting hot, wasting gas, etc..... You should at least disconnect the pin from that side while you are not using the e-brakes.
........... But I really do not believe that brakes could cause this problem. And a bent output shaft? hmmmm.... Is this an extra cab vehicle that uses a two piece rear drive line? I've seen the carrier bearing in the two piece drive line go bad and it causes a clunking noise/feel.
Please reply,
FIREBALL
Good point Mike....
The pinched line could be causing your brakes to drag. You may have enough pressure to push fluid past the pinch when you push on the peddle, but it may be holding pressure after you let off.
I agree with Mike, I doubt that your brakes would cause this prob. Check your ujoints, ubolts, and like Mike said if you have a carrier bearing check it also.
FIREBALL
Oh ya, make sure nobody put a zip tie on your drive shaft......that's one of my favorite pranks.
Tool Guy
Note to Self: wrap a bunch of zip ties on someones drive shaft....
84 Toyota- Cost $800, BS 3" Rancho Lift, Worn out RS5000s, 32" A/T's, Burned up Radio, New Plugs, and Wires
86 Chevy- Cost $500, Dead Battery, Out of Registration, No Inspection, a few holes in the bed
03 F150- Cost I still cry about, K&N FIPK, Dumped Flowmaster, Pioneer Head Unit and AMP, 4 ways and 10" Sub
03 F150- Company Truck, Stupid useless tonneau cover, stupid sticker telling everyone who I work for, wasted space in my driveway
lowgeared
I say jump it and see if the sound goes away.
P.S.  Send pics!
DontStall Rockcrwl
alright well i replaced the brake line, and the driver side rear brakes now it doesnt stick. but the clacking noise is still a problem. i have a one piece rear tom woods driveline. i noticed my flange from my third has a dent in it but i dont think this would cause the loud noise. i guess its off to bigger things? maybe blown bearings in the tranny?
FIREBALL
Jack up the rear and spin things. See if you can hear anything. Check those ujoints carefully too, if you have a dent, maybe the ujoint was damaged from the impact. Did you make sure your u bolts are all tight?
GrimReaper
Quote from: DontStall Rockcrwl on September 09, 2004, 11:09:40 PM
Sometimes you cant tell a u-joint is bad till you get the drive shaft off the truck. Also check the tranny and motor mounts. Under load things move and the motor torque causing driveline to shift.  Rodger Brown has some good info on his site about motor mount problems on www.4crawler.com
toyotaboy
when mine did that the dual cardan was hitting the horsshoe coller:smack: maybe hitting hte gas tank skidplate? does it do it more when turning one direction campared to another? maybe at a certain speed?
rest in peace Effay
01 taco needs, duals, front axle, linked rear, exo...
85 extra cab/cab for sale with efi harness. no drivetrain, will sell, make offer
Prismo
Mine still hits the horsecollar on hard braking. I thought I clearanced it enough, guess not. I also have the double cardan.
DontStall Rockcrwl
turns out, since i havent moved my crossmember back yet, the t-case was hitting against the cab. my driveline is bent so its making my entire t-case move.  :shake:
toyotaboy
is ur 1st case bolted down? at least ya figured it out :beerchug:
rest in peace Effay
DontStall Rockcrwl
one last question... since i havent moved back my crossmember yet with the dual cases, and the t-case being at an angle, could this maybe be part of the problem?>
DontStall Rockcrwl
alright, i moved the crossmember back and made new brackets and bolted it all up. still the noise. my buddy watch me as i drove and says the benbt driveline is moving my entire case making it hit the cab. so i guess its time for a new driveline. he said it looked like the splines were worn out
DontStall Rockcrwl
alright solved the problem i hope. i took the rear driveline out and put the front one in and drove with front wheel drive. no noise. i brought the rear driveline to my buddies shop, and he says, the splines were worn out, and its the worst splicer u-joint he has ever seen. guess it was worn out pretty bad. so he is gonna cut the splines off and weld a toyota spline from another driveline i have. hopefully it solves the problem. i'll give u guys an update.
thanks for the help
DontStall Rockcrwl
yeah......... cooool..... that didnt solve the problem either  :smack:   :rivers: guess its time to check the tranny?????
86rocktoy
'98 Tacoma HP60, 14blt, 5.38 ARB's, Atlas II, 39.5 Iroks
Have you checked your leaf spring bushings or shackles? How do those things look? Any excessive dirt or rust between leafs? :dunno:
DontStall Rockcrwl
all thats good. still havent taken apart the tranny or rear end yet. gonna do the rear end first. the reason im narrowing it down to the rear end, is because i drove it with only a front driveline and there was no noise at all. i cant remember what its called off the top of my head but that rubber piece between the crossmember and the t-case... seems like its going bad. it as cracks in it and is pretty loose. could this be causing the tranny to move  enough to be hitting the cab?
Prismo
If the mount is broken, it could let it move around a fair amount. Especially if you have a broken motor mount too. Did you check the rear pinion for play & the output from the transfer for excessive play when you had the driveline out?
DontStall Rockcrwl
there iis almost no play in the 3rd, and same with the t-case
DontStall Rockcrwl
took apart the 3rd and the r&p is F*cked. teeth missing. thankly i got genuine gear so its free replacement. i will give an update on how its going
ToyDuck
DontStall Rockcrwl
yeah i will for sure. hopefully this is the only thing wrong. gettin my new gears ordered tomorrow. hopefully my tranny isnt f*cked also.....
DontStall Rockcrwl
sweeet i threw in that 4.11 rear and no more noises. there is a minor howling sound when i let off the gas sounding like from the front t-case. other than that and the bent driveline, everything seems good. thanks for the help guys
GrandNational
You're tranny is good in this circumstance. I just payed $1000.00 to get mine rebuilt boy are those parts expensive. Last night I put the tranny back in and a new toyota clutch. took it down the road and pop pop pop pop, went home and could'nt sleep got up this morning put the truck back on the lift raised it up put it 1st and let it run. the popping noise to my surprise was'nt my tranny at all it was the ring gear missing about 6 teeth, now i need a new set of 5:29 gears . :yesnod: Thats going to be a money going outer :flamer:
the noise from the t-case isn't bad.  Almost all the toys i have ridden in have that noise with dual cases.  I got use to it.
