It makes this noise with the truck moving in 2WD and front hubs unlocked at low speeds while manipulating the clutch pedal. It almost sounds like the the clutch fork was hitting the cover plate fingers: I know this is astronomically unlikely, I'm thinking throwout bearing right now.
Also the front brakes are sticking. I can brake, but to make them unlock from the rotors I have to use a pair of pliers (!) I suspect this may be involved with the lurching problem.
Started by toymachine Engine
Started by DontStall Rockcrwl Engine
Started by Volcom Engine
Started by DAWGTOY Toyota Pickup/4Runner Tech 1979-95
Started by T Pennington Toyota Pickup/4Runner Tech 1979-95
