Dual Diaphragm Brake Booster In A First Gen
Started by ImmortalYota80, March 30, 2014, 09:39:14 PM
ImmortalYota80
I just did this upgrade on my 1980 pickup. The booster I used came out of a 1990 4x4 V-6 4Runner. I custom fabbed the new bracket using one of the existing 3/16 spacers then copied it onto a piece of 1/4 inch plate. Then used a piece of 3" tube for the spacer. I welded 4 carriage bolts onto the spacer that mates with the firewall. As far as a extension for the brake pushrod I did not take any pictures but I basically welded the old piece that connects to the brake pedal on top of the same piece that came with the new booster plated it up with some 1/8th inch for strengthen and it works perfect. The overall width of the new spacer is 1 3/4" and the booster clears the steering rod as well as the clutch master cylinder. Very happy with this upgrade it is probably one of the best upgrades I have done to my rig in awhile. Heres some pics enjoy :smokin:
Please excuse the boogered up hole I didn't have a hole saw that was big enough :shaking:
1980 4x4 Pickup, 22RE Swap, Marlin Built G54 Trans, 35/12.50 Cooper STT's, 4" Alcan Front springs/F150 rears, Open 5.29 front, 5.29 E-Locker Rear, Rebuilt Axles, High Steer
Build:
http://board.marlincrawler.com/index.php?topic=94416.new#new
Mtrdud
There are some good write ups on this on pirate and yota tech too
Mtrdud
I used one from I think a 92 p/u and was able to make it work without an adapter.  I have the part number somewhere.  It's a real good upgrade.
helipilot77
#3
I have read that a dual diaphragm from a 1986/87 turbo pickup is a direct swap. NAPA sells them new for $151.19
redneckcustoms13
It is a fact. I got mine from oreillys. Bolted right into my 1st gen.
01 double cab hunting truck
06 tacoma street truck
redneckcustoms13
Mine hit the intake on my 3rz swap as well. I dented it in and let it eat. Sitting in the truck as I type this. No issues.
helipilot77
I have one out of an FJ-80 in my 4runner. works great!
Erick561
I have an 87 2wd 1 ton brake booster in my 79 with 85 calipers and no lspv
SlayTank
More then one way to skin a cat. I just did this to my 85 pickup. 1988 Land cruiser dual diaphragm booster got from rock auto A-1 CARDONE 532570. master cylinder from 1994 4runner 4x4 CARDONE SELECT 132711 it has 1"bore. I do need to get a connector for the low fluid light now. Had to bend the lines a little bit but not to bad, worked out pretty well.
CrazyYota
Quote from: SlayTank on April 19, 2018, 01:30:44 PM
You have a lot less room in a first gen than a second gen truck.
