Author Topic: 22re turbocharged leaking fuel into oil?  (Read 2730 times)
inh
  • Male Posts: 23
  • Member since Feb '11
« on: Dec 03, 2013, 10:17:25 AM »
got a problem with my 22re on my 87 4runner, I turbocharged it and everything and came out great until I notice that fuel is leaking to my oil. I first checked the injectors and they are fine. before I turbocharged it ran great, I don't know if by not starting it for about 5 months could be factor to this problem. it was a slow project due to im in college and work. just need some advice on what I should take a look at before I start taking the head off and the intake manifold. any ideas? cause I im kinda lost right now :dunno:.
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Member since Jul '04
  • Lego Enforcement
    • Spinnin4s 4x4 Club
Re: 22re turbocharged leaking fuel into oil?
« Reply #1 on: Dec 03, 2013, 06:22:12 PM »
Did you just slap a turbo on an engine with 300,000+ on it or did you rebuild or replace it with a new engine? You could have some serious blow by on the rings if you didn't.
Cheesemaker
  • Turtle Points: 1363
  • Male Posts: 4,525
  • Member since Sep '04
« Reply #2 on: Dec 03, 2013, 11:35:21 PM »
Yeah we need more info.  Cause you just can't slap a turbo on a 22RE without a building it to handle the boost.  That and the 22RE uses some different setups and parts versus the 22RET.
86bobbedtoy
  • Turtle Points: 686
  • Male Posts: 3,938
  • Member since Oct '06
« Reply #3 on: Dec 04, 2013, 08:42:20 AM »
 done it and seen it done with no problems, remember the superchargers for 22r s? most the people that ran them never did anything to the motor.  I say run it and check the blow by at the oilcap, to see if its excessive goodluck
twistedtoy92
  • Turtle Points: -255
  • Male Posts: 3,781
  • Member since Dec '06
  • NFM Customs
« Reply #4 on: Dec 04, 2013, 12:42:44 PM »
X2 on more info. Now how much fuel in the oil are you talking about here??
SNOW WALKER
  • Turtle Points: 16
  • Male Posts: 172
  • Member since Dec '08
« Reply #5 on: Dec 04, 2013, 03:42:53 PM »
Sounds like an injector stuck open. If thats not it and your running the 22re ecu you should be running some sort of timing retard like MSD. The turbo 22ret ecu retards the timing quite a bit over the re. The higher compression and too much timing could prove to be a bit much for the rings to handle and could have damaged them, but it would smoke and burn oil.
1986 4Runner turbo sas high pinion,E-locked 4:88's,taco rear Detroit locker,22ret forged everything,
duels mc07-r10 cut 42's.
  • Momentum Man
  • Lego Enforcement
« Reply #6 on: Dec 04, 2013, 07:07:43 PM »
Says he checked the injectors first thing.
SNOW WALKER
  • Turtle Points: 16
  • Male Posts: 172
« Reply #7 on: Dec 05, 2013, 12:18:25 PM »
Just pulling them out and looking at em ain't gonna cut it. Did you have a shop that does injector work check them over? I had 2 sets of injectors and they all looked great but one wouldn't fire.
inh [OP]
  • Male Posts: 23
« Reply #8 on: Jan 05, 2014, 10:42:50 PM »
well the engine is rebuilt on has about 20,000 on it at the moment.
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
« Reply #9 on: Jan 06, 2014, 08:59:45 AM »
Means nothing if the bore was not checked for taper. If taper is out of spec it needs to be bored and oversize pistons and rings installed. If the injectors were not checked on a high pressure machine then just looking at them means nothing.
Last post Nov 16, 2006, 02:36:39 PM
by *FFC*
Last post Dec 26, 2006, 03:05:46 PM
by CTENG in KS
Last post Mar 08, 2007, 12:38:16 PM
by wingdaddy
Last post Mar 11, 2008, 08:58:49 AM
by RN37DD
Last post Jan 11, 2012, 05:32:44 AM
by GRW
