The only thing I dislike about the TG mounts is that they use garbage bushings that are proprietary -- strange, non-standard triangular shaped bushings. The HD t/case mounts we carry have always used high quality USA-made and standard round sized Daystar or Energy Suspension bushings. I'm not sure why their mounts are not a direct replacement. I didn't know this until now.Here is the mount we carry, made right here in California by Locktup with USA-steel and USA-made Daystar bushings (standard American size that can be found anywhere).We even charge less than TG while supporting great American products http://www.marlincrawler.com/armor/crossmember/crossmember-mount-hdBigMike
isnt it true that when switching to solid mounts you need to do both engine and tcase? iv heard that doing just one or the other can lead to serious issues like cracked cases?
Do these fit an 85 Auto Mike? I think mine is getting close to time for replacement.
is anyone using 4xinnovation motor mounts? i hear there pretty good and less vibration.
Sorry RS but they only fit gear drive t/cases. I updated the webpage to make it a bit more clear.
you sure that will work? it says up to '95 applications for that mount.
so you bought a product from a company, and it doesn't fit...... sounds like their product is junk at that point. and you want to modify things until it does fit...... good luck with that, hopefully it doesn't give you problems.
If you have to modify something that was supposed to be a direct oem replacement then you have junk in your hands. Doesn't matter that you can fix the issue with what amounts to a band-aid.
BigMike, about marlins motor mounts. is the new bolt need to be welded to the mount at all? and do you know what size bolt is used? if not ill figure it out. thanks for the info moded mounts sound like the way to go.
The only thing I dislike about the TG mounts is that they use garbage bushings that are proprietary -- strange, non-standard triangular shaped bushings. The HD t/case mounts we carry have always used high quality USA-made and standard round sized Daystar or Energy Suspension bushings. I'm not sure why their mounts are not a direct replacement. I didn't know this until now.Here is the mount we carry, made right here in California by Locktup with USA-steel and USA-made Daystar bushings (standard American size that can be found anywhere).We even charge less than TG while supporting great American products http://www.marlincrawler.com/armor/crossmember/crossmember-mount-hdThanks for the heads up Big Mike.I will call and order it today... will it be possible to actually speak with you? I have a specific issue we need to talk about.Thanks again.BigMike
I'll have to see about some pictures and additional details on the Marlinized stock mounts.* BigMike adds this to his very, very small TO-DO list which is almost always empty.
Started by 79coyotefrg Toyota Pickup/4Runner Tech 1979-95
Started by 84pickup Parts For Sale
Started by stillakid Parts For Sale
Started by Captain_Hero Project Research and Build-Ups
Started by yotarunner85 « 1 2 » Toyota Pickup/4Runner Tech 1979-95
