lspv
Started by mossyoak85yota, April 07, 2013, 10:44:03 PM
mossyoak85yota
does anyone make a kit eliminate the lspv valve or would i be better of to just tie it up? if so how high do i tie it?
:welcome:  search is your friend, also you are in the Check-In section where we just say hello to new members this is not a tech section and most of the tech guys don't come around here much so you won't get much info other than a Hello and welcome to the board comment. I noticed you also posted a bunch of other tech questions in this section which will generally get you the same results of not much info. As to your question here I unhooked my LSPV rod and bolted it to the bottom of the cabin on my 4Runner, I don't think there will be a point to bolt to on a pickup but if you click on the link below it will show you what I did to leave it in the full open position.
http://board.marlincrawler.com/index.php?topic=85642.30
mossyoak85yota
thanks for the feed back
