I know I won't get a whole lot of info here, but I'm throwing this out there anyways as its kinda interesting tech.
In my research for engine swaps into my old 88 toyota I came accross the newer chevy colorado and gmc canyon trucks. I had thought that every single truck on the market today was drivers drop on the front d-shaft, which puts the exhaust on the pass side, right where our pass drop d-shafts are. This makes it difficult in cali as the smog refs want the exhaust as it came off the donor vehicle. Oddly enough, the colorado and canyon trucks as well as the H3 hummers are all pass drop front d-shafts! The exhaust is still on the pass side which is odd, but they had to work it and the cats around the front d-shaft and t-case, so it should be reasonable to package into a toyota.
Ok, so what, exhaust isn't the end of the world on the other swaps. I started looking at these more in depth, all aluminum blocks, vvt on the exhaust, and timing chains! The numbers look pretty good too, the 3700 puts down 242hp and 242lbft at the crank! They have an odd bellhousing bolt pattern though, but the auto in those trucks is just a standard old 4L60E, so thats easy, and the manual is an Aisin Ar5 trans, which is apparently in the same family as the AX15, R150 and R154. So theres the possibility of kluging a trans together to get a manual.
I'm curious if anyone has any input into these engines? Any gm techs out there? Are they good, bad, POS motors? Does anyone have any weights, or other dimensions?
http://www.underhoodservice.com/issue/article.aspx?contentid=92795Here is an artical about bolting a supra 2JZ in front of the Ar5 trans:
http://carscoop.blogspot.com/2011/06/pontiac-solstice-gets-engine-transplant.htmlThanks,
Kevo
