Author Topic: T-case help...  (Read 1750 times)
TuffToy
  • 85 toy,Junkyard wars reject
T-case help...
« on: Jun 08, 2002, 12:05:31 PM »
I have wasted two t-cases in less than a year, in both the rear bearing has ruined the rear output shaft housing (wallered it out ). The bearing was spinning in the housing. the last t-case only lasted three months, I've checked the driveshafts, they appear to be ok.         Does anyone have any "good" ideas of what is causing this?I had a 4" skyjacker lift ,5:29's, in a 85 toyota reg.cab 4 cyl. stock t-case,Marlin tranny...only been running on 5" All Pro springs about 550 miles. All the help/advice is greatly appreciated....    Thanks Phil
« Last Edit: Dec 31, 1969, 04:00:00 PM by 1056988800 »
  • Administrator
  • Turtle Points: 2159
  • Male Posts: 18,292
  • Member since Apr '02
  • 511:1 Club
Re: T-case help...
« Reply #1 on: Jun 10, 2002, 05:49:59 PM »
Wow Phil,
I would really blame your driveline either its out of balance or its too long and is bottoming out and applying pressure to the output shaft at an angle.
Does the slipjoint on the rear shaft move easily or is it rather firm moving it in and out?
Regards,
TuffToy [OP]
Re: T-case help...
« Reply #2 on: Jun 12, 2002, 12:04:54 PM »
The slip-joint moves easy , by hand... when it is off the truck. I have double checked the rear drive shaft , it isn't too long(I've used custom d-shafts & stock ones... all the same length) Do you think that the drive angle ...the t-case to the d-shaft angle is too great? Do you think that I need to drop the t-case down a little bit to compensate for the lift ?  I use this truck as my daily driver... Approx. 150 mi. per day, 3-4 days a week. Thanks     Phil
Last post Nov 14, 2006, 06:22:55 PM
by BLACKDOG
Last post Dec 27, 2006, 02:04:28 PM
by AreYouSure
Last post Jan 26, 2007, 01:04:30 PM
by jimbo74
Last post Apr 27, 2007, 06:19:50 PM
by limegreen82
Last post May 23, 2007, 09:37:34 PM
by Wermz84
