THK's 86 4Skinner Build-Up (My Fiancee was hit in my '12 Focus Today)
Started by THK Matt, May 17, 2012, 09:39:06 AM
Quote from: 46&2 on May 19, 2012, 07:56:52 PM
Obligatory-finishthisonefawkersoyoucangowheelingdamnit-post  :biggthumpup:
:beerchug: I deserve that Brutha.
Engine soon, and front swap.
Picked up an upper intake, throttle body, exhaust manifold, AFM/Air Box, Radiator Fan, Heater tubes, EGR Valve and crossover plate to make block off plates. rocker arm assembly, valve cover, alternator and some brackets.
Also picked up my inner axles w/ birfs, diff, and some misc bearings.
Thanks again Cody, you are the MAN!
Possibly picking up a front hanger, bushings, shackles and making my front spring pack this Friday.  :crossed:
That means this weekend, my front will be swapped. :P
Then its Engine &/Or High Steer after that.
mudaddict
possibly we do'nt like to see possibly's here!! lol!
98 Taco- Super charged, sas'd, bobbed, locked,taco boxed with 39's
Taco Build http://board.marlincrawler.com/index.php?topic=88901.0
I work At
All Pro Off Road
depends on the size of my paycheck lol if not this friday.... June 10th :]
mudaddict
ok understandable i hate that waiting period of having to save money but makes it all more worth it when you can afford it.
I work At
All Pro Off Road
Quote from: mudaddict on May 23, 2012, 09:20:49 PM
No doubt.  :P
Picking up my Hanger tonight and maybe some other stuff?
Picked up my front hanger tonight, its beef. can't wait to weld my hanger and jigs up tomorrow. :willynilly:
and heres to show what it will look like welded up.
She's ready for surgery!
Mudfanatic92
Looks sick MAN!! Cant wait to see how it will look. Ill see if i can get you springs this weekend.
Rockin dude, let me know. soon as i have the 48s, Ill cut the ifs off and hang the front end.
When u go to Jesse's to pick up the hanger. ill try and have him have my set of 5.5in shackles made up to give to you as well.
Unless I head there myself. idk. lol still gotta find out what he charges on the shackles.
I like how the front hanger has a little slider spot on the front...  So what all do you need as far as major components go to get this thing up and going?
Engine, Trans, Tcase, Drivelines, High Steer and shocks. :]
Mudfanatic92
I  think i can get you the Engine, Trans, and 2 cases.
Quote from: nisota on May 25, 2012, 11:07:08 AM
The interior comment was just a suggestion no disrespect meant to you or your build.
None taken :]
On a better note, here is what I did today :P
Nimyad
I'm not sure I would have welded it all in yet especially not knowing where you wanted your axle placed and what not
Mudfanatic92
Quote from: THK Matt on May 25, 2012, 04:05:13 PM
Gonna have to make or get some gussets for the end and weld them to the frame... just to make extra beefy... Can never be too cautious  :thumbs:
And its looks super clean  :thumbs: :beer:
yota_krawler
Quote from: nimyad on May 25, 2012, 04:40:01 PM
x2
I don't know if I would have commited to that either but it looks like the spring bolt holes are about 1/2" or so back from the front of the frame. That's right where mine ended up for rears up front so I'm guessing you'll be OK with that placement.
I used 3rd gen rears which are longer but they ride and flex great and get the front end even further to the front. I think the early rears are easier because you don't have to scoot your steering box as far forward.
Im going with shackle tubes under the frame, so im good to go. :]
My hole saw bent and i dont wanna deal with it. so under the frame it goes.
Quote from: Mudfanatic92 on May 25, 2012, 04:52:45 PM
Most definitely, its not done. :]
Btw, the Spring Pad Spacer is welded on as well  :beerchug:
NorCalToy
how big is the drop on that hanger?
and if youre gonna run shackles under frame pick up some shims to throw under the leafs and watch shackle length so your pinion angle doesnt get too crazy. Same boat im in now, cant increase my shackles from 3.5 to 5 until i get some shims to throw up there and then i gotta actually pay attention to some of my alignment angles and it gets all fawked off.
:flamer: IFS
I've got that all in the works.
and I will go measure it right now.
EDIT: From the bottom edge of the factory frame to the center of the spring mounting hole is 4in.
:popcorn:
Gotta finish it up tomorrow. :P
Ran out of cut off wheels, haven't picked any up yet. Should have the axle ready for mock up. enough bolted on... to get it under the 4runner on Thursday and measure for shock hoops, shocks, rear spring hanger placement, and figure out where my steering box needs to be.
NorCalToy
you paint everything you own sail blue...
:flamer: IFS
Mudfanatic92
It's better than that 2-tone red and brown ;) lol
At this rate you will be done before I am and I have a two week deadline...
Quote from: NorCalToy on May 29, 2012, 11:00:17 PM
What can I say, its my favorite color.
Quote from: H8PVMNT on May 30, 2012, 08:15:14 AM
Idk bout that right now, I just lost my job and may go to ND to work. ill be makin bank though.
Quote from: Mudfanatic92 on May 30, 2012, 05:17:44 AM
No doubt.  :beerchug:
