Author Topic: Project Undertow *2RZ Turbo Crawler*  (Read 88852 times)
Tungsten Slayer
  • Turtle Points: 89
  • Member since Aug '11
Re: Project Undertow
« Reply #120 on: Feb 25, 2014, 04:19:51 PM »
I have it wired to a temperature switch so it kicks on and off and doesn't kick on that much when crawling, but probably more in the summer.  I am kinda torn using electric fans because I have never thought them to be very reliable.  On the other hand these are affordable and this is the first time I have had one go out, so I will just replace it. :eek:
It is so awesome to be out and wheeling this thing.  It just goes where I point it until the rocks swallow me whole, I found myself shipwrecked a few times, but I think a lot of it is driver error :boozer:   Suspension is working out great, no hopping or suspension unloading under throttle and it feels a lot more stable than the last one I built before this.  I am still digging the trailing arms when they hold together and the 2rz to auto trans is still getting the job done.
I did my first front dig which worked out great :sly: and ended up disconnecting the rear d-line after the breakage :moon:, so the Dana 300 has already proven to be an awesome addition to an already good thing.  Just working out the kinks on it now and there have been a few small things which is to be expected.
Wainiha
  • Turtle Points: 743
  • Male Posts: 1,170
  • Member since Jan '12
« Reply #121 on: Feb 25, 2014, 07:55:22 PM »
 Shipwrecked.....funny stuff.  I pictured the pahard mount instantly :rofl2:
2000 3.4L xtra-cab Tacoma.
Icon C/Os
Marlin 1200lb. clutch
Marlin short shifter
FLOODED...GONE
2005 4.0L xtra-cab Tacoma
FLOODED...GONE
2012 4.0L xtra-cab 4x4 Tacoma
Automatic...Don't shoot...
 King resi C/O
and Total Chaos UCAs
Crunchy Taco
  • Turtle Points: 90
  • Member since Sep '13
  • Flexiest leaf sprung taco I kno
« Reply #122 on: Feb 25, 2014, 08:03:09 PM »
Sounds like a successfull build.  That's cool how you have yer fan hooked up that's how all the cool kids are doin it. It was probly just that fans time to go.  New one should do the trick.
98 Tacoma ex cab, Garrett T3 turbo 7psi, w56, 2.28 duals, ceramic sprung puck clutch, toyota solid axle, Tacoma rear axle w/ e-locker, plated frame front and rear, fuel tank raised with custom armored cradle, 1 ton steering 35" general grabbers wheeler/DD built from stock http://board.marlincrawler.com/index.php?topic=95652.msg1066733#msg1066733
Tungsten Slayer [OP]
  • Turtle Points: 89
« Reply #123 on: Mar 07, 2014, 10:53:13 AM »
Update!
The trailing arm has been fixed and tested :eyebrow: as well as fixing the other side before it broke.  Ordered a muffler and redid the exhaust.  It now exits passenger side back of the rig.  I used a Thrush turbo muffler and it is pretty quiet now which I like!
Taurus fan magically started working again :headscratch: so I am going with it.
Purchased a scanguage ii for digital guages and trouble code reader, but my OBDii port is not connecting to the scanner :tantrum:.  I am in the process of double checking my triple check on the wiring, but I feel a bit lost at sea when it comes to wiring.  I've got a real good idea of what needs to go where, but I think I need an ohm meter to see if my E5 plug is giving info to the D7 data link connector..hhhmmmm
Crunchy Taco
  • Turtle Points: 90
« Reply #124 on: Mar 08, 2014, 08:25:28 AM »
You need an unmulested harness to refer to.
Crunchy Taco
  • Turtle Points: 90
« Reply #125 on: Mar 08, 2014, 08:38:09 AM »
You up in Washington ? Depending on how far away you are from Portland I could always cruise up and you could look at my interior harness in my truck. Might have pull some dash pieces out to see what you need. I wana buy one if the badass Toyota wire diagram books and everybody's problems would be over. All the research on wiring I've done and I never researched where to buy one of those books. I'm an idiot
  • Turtle Points: 89
« Reply #126 on: Mar 08, 2014, 11:18:10 AM »
I've got good diagrams and a good tech line to call (Justin @ Toy Only Swaps).  Everything looks like its wired correctly and the motor runs awesome.  When I first cranked the motor however I smelled burning and shut everything down.. rechecked everything and it was all legit.. I am not sure if the computer had been compromised at the wrecking yard, sometimes they sit out in the rain or get dropped by a worker :hammerhead:..  I am thinking about trying another ECU to see if the computer is toasted a little.. Here's part of the wiring diagram's I have printed off and redneck laminated with packing tape :gap: for a trail copy or whatever..
  • Turtle Points: 89
« Reply #127 on: Mar 08, 2014, 12:13:13 PM »
Pic of the link repair.. This is 2 TIG passes and then a weave over.. I filled the rest with the MIG.
And the new exhaust set up!
Wainiha
  • Male Posts: 1,170
« Reply #128 on: Mar 08, 2014, 12:57:29 PM »
Tungsten Slayer, what kind of weather do you have?  Are you worried about the exhaust wrap holding moisture and rusting the metal?
What brand exhaust wrap?
Icon C/Os
FLOODED...GONE
FLOODED...GONE
 King resi C/O
  • Turtle Points: 89
« Reply #129 on: Mar 08, 2014, 02:48:20 PM »
I live in Bend or. so it's pretty dry most of the time.  I am not concerned about rust on the exhaust.  It will hold up for quite some time.  I don't remember the brand of the wrap, but I do remember it being organic material.
Wainiha
  • Male Posts: 1,170
« Reply #130 on: Mar 08, 2014, 04:38:49 PM »
I like Bend.  I lived in Corvallis and Portland for 8 years.
Thanks for the response on the wrap.
Icon C/Os
FLOODED...GONE
FLOODED...GONE
 King resi C/O
  • Turtle Points: 89
« Reply #131 on: Mar 08, 2014, 04:44:29 PM »
Yeah man, the heat wrap keeps a lot of the heat inside the exhaust system.  I am really happy with it!  I re-used my wrap for this second exhaust.  For some reason I pictured it getting hard and being a 1 use item, I think because it looks like some of the hard cast I have had on my body from breaking bones. haha
Bend is a fun place if you like the outdoorsy stuff which is why I moved here.
Crunchy Taco
  • Turtle Points: 90
« Reply #132 on: Mar 08, 2014, 06:32:22 PM »
My wife's fam lives in bend and p ville. I like wheelin b the p ville res. its fun.
  • Turtle Points: 89
« Reply #133 on: Mar 08, 2014, 06:44:44 PM »
Hey Toy army.. I got my schematics second hand, but check out alldata.com.
Crunchy Taco
  • Turtle Points: 90
« Reply #134 on: Mar 08, 2014, 07:03:41 PM »
That's what I was thinkin bout. All data. Thanks. It would just be nice to have some decent diagrams when I help buddies on swaps or if I ever have any major probs with my Tacoma wiring.
Crunchy Taco
  • Turtle Points: 90
« Reply #135 on: Mar 08, 2014, 07:06:53 PM »
You figure out yer obd2 connector.
Wainiha
  • Male Posts: 1,170
« Reply #136 on: Mar 08, 2014, 07:44:10 PM »
I have some wiring diagrams and some FSM stuff.  I would be happy to share, but I'm not sure I know how to send some of those file types.
I won't post them here.  I don't want Marlin and Mike to get in trouble.
Icon C/Os
FLOODED...GONE
FLOODED...GONE
 King resi C/O
Crunchy Taco
  • Turtle Points: 90
« Reply #137 on: Mar 08, 2014, 09:55:27 PM »
You could prob email them or something.  I just wana buy one of the good books so I have it for good.
Crunchy Taco
  • Turtle Points: 90
« Reply #138 on: Mar 08, 2014, 10:02:10 PM »
This all started cause I thought maybe tungsten slayer needed help figuring out his obd2 plug. I was kinda bringing up how I would like some good clear user friendly diagrams for Tacoma 4 banger wiring. I know theres a lot of downloads out there and stuff others post. I think ill check out all data. If I was better on a computer it would prob be really easy for me to get some good stuff. I've heard of books you can buy thought that would be cool to have.
Crunchy Taco
  • Turtle Points: 90
« Reply #139 on: Mar 08, 2014, 10:12:43 PM »
But yea when tung slayer said his data link connector wasn't working I offered to bring my truck out so he could look at my int harness and maybe see what was wrong with his by copying mine I'm not in any big need of any wiring diagrams at the moment. There's prob a way easier way than tearing into my dash It was just an idea. Good luck on that obd port.
  • Turtle Points: 89
« Reply #140 on: Mar 14, 2014, 04:51:23 PM »
Swapped out my ECU and meowsers, it works!  I had a manual ECU and traded for an auto ecu which didn't require any wiring :beer:
Crunchy Taco
  • Turtle Points: 90
« Reply #141 on: Mar 14, 2014, 06:59:17 PM »
sweet deal
  • Turtle Points: 89
« Reply #142 on: Mar 18, 2014, 07:27:26 AM »
pics from swartz
Wainiha
  • Male Posts: 1,170
« Reply #143 on: Mar 18, 2014, 01:03:33 PM »
I was picturing an old man.  You look too young to be that good of a fabricator. :gap:
Icon C/Os
FLOODED...GONE
FLOODED...GONE
 King resi C/O
  • Turtle Points: 89
« Reply #144 on: Mar 18, 2014, 02:07:48 PM »
Just turned 30 :beerchug: But I am a salty old sea dog at heart haha
Bam
  • Turtle Points: -137
  • Member since Feb '14
« Reply #145 on: Mar 18, 2014, 03:52:04 PM »
I need to go check out Swartz one of these days.
So we gonna see this thing at Groundhog?
"Buy it, use it, break it, fix it, trash it, change it, mail, upgrade it..." - Daft Punk
  • Turtle Points: 89
« Reply #146 on: Mar 19, 2014, 10:48:33 PM »
Relocated the power steering pump today making the relocation bracket adjustable :think: so I can still tension the belt.
« Last Edit: Mar 19, 2014, 10:54:12 PM by Tungsten Slayer »
Crunchy Taco
  • Turtle Points: 90
« Reply #147 on: Mar 20, 2014, 06:07:09 AM »
It's hard to  be crummy at fabrication when you been doin it since age 12.
Crunchy Taco
  • Turtle Points: 90
« Reply #148 on: Mar 20, 2014, 06:09:33 AM »
U runnin a v belt off the front of that 2rz crank pulley?
  • Turtle Points: 89
« Reply #149 on: Mar 20, 2014, 09:26:01 AM »
It's a 4 rib serpentine belt, just like the factory power steering belt, only shorter.  The factory one is 34" and this one is 31.5".
Last post Sep 15, 2006, 03:41:02 PM
by KWP
Last post Jan 30, 2007, 10:30:03 PM
by mudgrapler
Last post Jul 19, 2009, 09:47:52 PM
by GhostMoney
Last post Jul 17, 2013, 12:20:16 AM
by Tyler+Ashleys4runner
Last post Jan 22, 2023, 09:32:15 AM
by Nation
